Results 1 to 5 of 5
Thread: Pod filter.
    VS 95 Berlina
    Oct 2008
    Default Pod filter.
    Howdy, can any one tell me what to do with the airbox sensor that plugs into the back top portion of the air box if one was to put a pod filter on a 95 VS, I'm kind of more inclined to go with a K&N or Fram hi flow that goes straight into the standard box but still interested all the same, also do you need to have any ecu alterations done if changing to a hi flow?
    Thanks.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    you don't need to have the ecu/tune altered for a filter change. if you do go with a POd filter then you would need to fit the sensor into the intake just after the filter. it's the air intake temp sensor and the ecu needs it to determine the correct fueling
    Body by Holden, Soul by Brock
    the Legend will live forever
    VX SS M6
    Jun 2005
    theres a pod adaptor you can get and it has the spot for the air temp sensor
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    better off with a K&N filter and cold air intake than a pod filter, cleaner, less heat, etc
    SIR LS1
    the two ton go kart
    VS 95 Berlina
    Oct 2008
    Default thanks
    Thanks very much guys. going with Fram hi flow and found hsv cold air intake.
  1. Filter for CAI
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 11:29 AM
  2. VP VR VS K&N Air filter
    By hispeedvp in forum Swap / Wanted to Buy / Trade
    Last Post: 23-09-2005, 08:54 PM
  3. pod filter on vn 5L on gas
    By vncala in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2005, 11:27 PM
  4. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
  5. Pod Filter?
    By Shivaga in forum The Pub
    Last Post: 20-07-2005, 01:29 PM
