Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: pros and cons of dumping exhaust at the diff
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    Arrow pros and cons of dumping exhaust at the diff
    as title says, any info whould be great also.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Cons: It's illegal, can fill your cabin up with fumes and then you pass out and die when your car smashes into a building filled with people, and if you survive then you will have to deal with that (could get expensive).
    Pro's: Sounds as tuff as nails on a 304 or LS1, sounds hell gay on V6's because you can't make a V6 sound good or like a V8 no matter what you do to it. It will still sound like a V6 in comparison to a V8.
    I'm sure there is heaps more but those are my two main ones.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by Cobez View Post
    Is it illegal? Im trying to find this out but cant find a definite answer and well the legal guff makes no sense to me.
    Division 2—Exhaust systems
    148—Exhaust systems
    (1) The outlet of the exhaust system fitted to a motor vehicle (except a bus) must extend:
    (a) behind the back seat; and
    (b) at least 40 millimetres beyond the outermost joint of the floorpan that is not continuously welded or permanently sealed; and
    (c) to the edge of the vehicle, if:
    (i) the body of the vehicle is permanently enclosed; and
    (ii) the vehicle is not fitted with a vertical exhaust system; and
    (d) no further than the edge of the vehicle at its widest point.
    (2) The outlet must discharge the main exhaust flow to the air:
    (a) if the vehicle is fitted, or required under a law of this jurisdiction to be fitted,
    with an exhaust system with a vertical outlet pipe:
    (i) at an angle above the horizontal; and
    (ii) at least 150 millimetres above the cab of the vehicle; and
    (iii) rearwards or to the right of the vehicle; and
    (b) in any other case:
    (i) horizontally or at an angle of not over 45
    (ii) under 750 millimetres above ground level; and
    (iii) rearwards or to the right of the vehicle.
    Any Ideas?
    Thanks
    Matt
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    hot exhaust blowing on the petrol tank ? Aside from heating the fuel and loosing power, hot petrol is more explosive, so I would not like to ride in your car with the mod mate...
    Sep 2008
    Quote Originally Posted by greenacc View Post
    Na there's nothing under there i probably should of mentioned that its a Ute and the tank is behind the cab away from anything evil.
    Sep 2008
    qld modifications book
    Exhaust systems
    Exhaust systems must comply with Queensland
    legislation which includes the following conditions:
    • Exhaust headers (extractors) may be fitted to any
    motor vehicle, provided:
    they do not foul any part of the steering,
    suspension, brake or fuel systems
    all fittings for emission control equipment
    (E.G.R. valve, oxygen sensor, pipes and so on)
    are incorporated to ensure the vehicle maintains
    compliance with Australian Design Rules for
    vehicle emissions
    exhaust systems must continue to comply with
    relevant legislation or Australian Design Rules for
    vehicle noise.
    • The exhaust outlet must extend at least 40mm beyond
    the furthermost outboard or rearmost joint of the floor
    sealed which could permit direct access of exhaust
    gases to the passenger compartment, but not beyond
    the perimeter of the vehicle when viewed in plan.
    • The exhaust outlet, if to the side of the vehicle, must
    discharge to the right hand side of
    the vehicle and downwards at an
    angle to the horizontal of not less
    than 15 degrees and not more than
    45 degrees.
    • The exhaust outlet, if to the rear of
    the vehicle, must discharge at not
    more than 10 degrees above or 45
    degrees below the horizontal.
    • All exhaust and muffler systems
    must be free of any leaks or
    mechanical faults and should
    be adequately supported.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Ah, its a ute, thats totally different, you have a lot more freedom as you only have 2 doors, and i think the main issue with exhausts is they the outlet must be behind the rearmost doors, ( and away from the fuel tank LOL ). So the biggest issue i can think of for you is blowing black shyte all over the side or undercarriage. Why dont ya get some big side pipes like an AC Cobra !!
    Aug 2008
    Do you really think black dust/smoke etc would do much to the undercarriage especially when it points down sort of?
    Thanks for the info keep it coming
    Matt
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    i have had no problems * above pic is my car * no issues with dust or undercarriage and its not loud, just a nice deep tone and its only a little before the diff so i have no issues with smell or anything, cops cant see it either, if u want a cheap exhaust i reccomend this 100% felt a bit of a change in pickup out of it too
    SIR LS1
    the two ton go kart
    Aug 2008
    Quote Originally Posted by davecunno View Post
    Got a step by step guide of what you did? Just took off the rear part of the muffler and welded a tip onto the middle muffler?
    What about it wouldn't be legal? Say if a coppa pulled ya over? Id really like to know if anything is which i don't think there really is?
    Thanks
    Matt
    Sep 2008
    cheers mate , how many mufflers r on it is it just 1?
    do u have a dummy like a exhaust hanging from the back that doesn't go any where? so it looks like u have a standard exhaust.
    keep em coming.....
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    its still in normal place as the old muffler, i just cut off the old one, welded on a hi flow one and made a bracket for it. then cut a short bit of pipe off the old exhaust and welded it on to angle the sound to hit the ground. i cant see why it would be illegal , if ur in adelaide feel free to come check it out
    SIR LS1
    the two ton go kart
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    i thought about putting a dummy off the tow bar frame but ehhh why bother lol its a ute, its only finishing like 4 foot sooner lol
    SIR LS1
    the two ton go kart
    Aug 2008
    HAHA i am actually in Adelaide i live in the southern suburbs. I want to do this but i also want to keep the exhaust intact incase i get picked up and need to put the stock one back on. Just curious is the VS Commodore Sedan the same exhaust as a ute say from the CAT to to main centre muffler because if so i might visit the wreckers and grab one and use that so i can unbolt my current stock system and put it aside. Would it still sound better with a stock CAT and Main muffler dumped just before the diff u reckon?
    Thanks
    Matt
  15. #15
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    go to advance auto salvage mate, they have heaps of vs utes and a **** load of vs ute sports exhausts, mighta been sold but out the back is a custom twin system, but also mines a v8 with a dump...i dunno how it would sound on a v6... mine has 2 more cylinders so it sounds more right :P
    SIR LS1
    the two ton go kart
  16. #16
    Aug 2008
    LOL damn you i would of got those 2 more cylinders but i didn't want to put in an extra $20 a week in fuel lol. Where is this Auto Salvage place as i usually just go to U-PULL-IT. Do you think a sedan exhaust would be the same because if so ill probably just grab one as im hopefully gonna spend more money on the audio and just want some extra noise for the exhaust :P + the extra 60rwkw and 6l/100km :P
    On another note you wouldn't happen to know if the front speaker pods in the ute will fit 6.5 speakers instead of the stock 6's easily hopefully without mods by chance lol?
    Thanks dude
    Matt
  17. #17
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    aas is on osullivans beach rd, see the manager dave and tell him Dave sent u in and he will look after u. top bloke. and with a vs, i reccomend a 2.5 inch system with hi flow can, super turbo muffler and then pipe straight thru all the way to the back, nice deep tone
    SIR LS1
    the two ton go kart
  18. #18
    Aug 2008
    Well this was the other option what sort of costs for this are involved for a CAT Back system as you mentioned above which i presume includes a high flow cat, 2.5inch, high flow muffler straight through to the back?
    If i went to AAS and asked dave and said dave sent me would he cut me a deal of some sort cause i presume your good mates? If it was the right price i would definitely think about it as i thought about that CAT Back RedBack system on ebay for 2.5inch with a single muffler for $200
    Any more info much appreciated
    Thanks Dave
    Matt
  19. #19
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    ur budget for a exhaust is between 225 - 500 custom made depending on the brands and such u go with. i used to work at aas and daves a good bloke and i know hes not dodgy and looks after people and when i was working there 3 months ago there was about 5 commo utes with good new sports systems, so they can definitely help
    SIR LS1
    the two ton go kart
  20. #20
    Aug 2008
    So say for a decent brand exhaust system with a High Flow CAT, High Flow Muffler and Straight Through 2.5inch Pipe with a Tip would that probably be around the $500 dollar mark. I presume this is the sort of setup these days if not please do fill me in. Also all i have heard of for exhaust brands ar Redback or Lukey.
    Just looking for rough prices etc and i have a pit too if that doesn't include installation.
    Thanks
    Matt
  21. #21
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    if u get a welder and a hi flow muffler ill help you do the same muffler ive got lol
    SIR LS1
    the two ton go kart
  22. #22
    Sep 2008
    hey dave ,
    if i cut off my muffler and dont put another 1 on whould it be way to loud????? would it sound stupid?
    thanks mate
    fuzzy
  23. #23
    Aug 2008
    Quote Originally Posted by fuzzy2308 View Post
    hey dave ,
    thanks mate
    fuzzy
    If you left the rear resonator(muffler) off it would be alright as that's what i am thinking of doing but if you removed both it would be bloody loud i reckon. When opened up then it would be bloody insane lol.
    If you get what i mean, keep the main muffler :P
    Matt
  24. #24
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by jokerflingo View Post
    Matt
    easy to test that, just take it off for a run up the street. ive done it, but for a V6..... no.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  25. #25
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Dumpers are fine, don't bag them out until you've lived with a set for a while. My 304 VR has had twin 2.5" dumpers for years, I'm not dead from exhaust fumes and my fuel tank hasn't exploded, never had trouble with hot fuel either, car makes perfectly good power. I've been pulled over half a dozen times and never once been in trouble for noise or exhaust regulations.
    Yes they are illegal, it's a choice the owner has to make.
    Sam
    WTB: mulberry VN interior parts
  1. LPG - Pros V Cons
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2008, 01:56 PM
  2. diff dumping exhaust is it illegal
    By ViN3Y in forum General
    Last Post: 10-08-2008, 11:59 AM
  3. Pros and Cons of VY's?
    By 1vngal in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-07-2008, 07:49 PM
  4. Kalmaker ECM Pros & Cons
    By onsta004 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 11:02 AM
  5. What are the pros/cons of a 3.45 VL diff?
    By DavidPartay in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-09-2004, 02:14 PM
