Results 1 to 21 of 21
Thread: How do i remove the dirt from coolant tank
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    Exclamation How do i remove the dirt from coolant tank
    Whats the best way to remove dirt and junk from my coolant bottle, ive tried to rince it out with water but its not coming out
    VR V6 Manual
    Aug 2008
    Central Coast, N.S.W
    i used degreaser and a brush. buy spray degreaser for like $5 and it comes right off
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Good idea to just use some degreaser or soapy water and a pressure washer to remove the gunk thats in there. Much easier if you remove the entire coolant tank from the car, its easy enough to do as its only two screws.
    Just remember though, if your coolant tank is looking like that, then chances are parts of your cooling system will be too, so if you haven't done so already, it might be an idea to give the entire system a really good flush out, and then refill with the correct grade quality coolant.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    i removed the tank from my cars. Good pressure spray has always worked. safe too.
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    yeah i just bought the car so im tidying it up atm, most of the k's are from country driving so the crap is like brown soil :S
    how do i remove the front bar?
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    i soaked it in methol spirit and domestos over night and that didnt work so hopefully degreaser will do the job
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    its most likely not not soil, its most likely the pellets that have caused the muck. New tank is an option
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Agreeded with all methods mentioned, though if you dont have a high pressure gun try half filling with soapy water then put some small stones in about 5-6 and hold your hand over the filler hole and shake the s**t out of it.
    On coolant grade, most coolant you buy is 1997 grade stuff mixed with soft water (deminralised/distilled) that has stuff that will lube your water pump seals etc.. so no more 3 lube pellets from holden, lol
    P.S rain water from a clean R/water tank works well to as it contains no ground minerals.
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    throwing this out there... something slightly acidic .... bicarb soda
    SIR LS1
    the two ton go kart
    VS 95 Berlina
    Oct 2008
    Howdy, just did mine whuch was pretty clean anyway but I removed the tank, rinsed out with warm water then 1/2 filled with hot water and added 1 finnish power ball dishwasher tablet, shook around till it desolved topped up with hot water, had a coffee then rinsed it out, came up like a new one. Tablets are slightly or rather very alkaline.
    94 vr ute
    Oct 2008
    i just bought some CLR clear in a spray bottle to clean up an old claw foot bath and it did wonders so gonna give it a go i the coolant ressie when i get around to it.
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    thnx for repplies guys il give those methods a go if they dont work out il just buy a new one
    VR
    May 2008
    dude - degreaser. Old mate at the top was on the money, thats how I did mine. If you have trouble, flood the c.u.n.t with degreaser, chuck some gravel in, put the cap back on and shake it like an english baby-sitter with an un-wanted red-headed love-child. Tally-Ho!
  15. #15
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    yep, degreaser or the finish power ball will work great. The metho didn't work cos that brown crud is non-polar, so needs a non-polar solvent like hydrocarbon, or a strong detergent like the powerball to dissolve it. Whoever came up with the powerball idea THATS GOLD.
  16. #16
    VT
    Apr 2005
    QLD
  17. #17
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
  19. #19
    Inkar's Avatar
    Inkar is offline :]
    Vr Berlina
    Apr 2008
    Melbz
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    could also chuck in pea gravel and shake the bottle up, thta usually works
  21. #21
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    swivel sweeper bahahaha.
    Petrol?
  1. how do u remove fuel tank? ASAP!
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2010, 09:53 PM
  2. how to remove Water in fuel Tank
    By Lafanter in forum General
    Last Post: 22-04-2008, 09:06 PM
  3. vt coolant tank
    By elaine collins in forum VT - VX - VU - WH - V2
    Last Post: 13-04-2008, 11:40 AM
  4. Coolant stuck in reserve tank
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 10:15 PM
  5. Coolant overflow tank
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-08-2006, 10:01 PM
