Results 1 to 21 of 21
Thread: Car leaking a lot of trans fluid
    Gen 3 VT2 Berlina wagon
    Aug 2008
    Default Car leaking a lot of trans fluid
    As the title says, my car is suddenly leaking a lot of trans fluid, like from last night to now it has made a puddle half the width of the car. Is there an easy way to fix this or is it a job for a professional?
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    im happy to have a look, how far are u from port rd
    SIR LS1
    the two ton go kart
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Do you know where the leak is coming from? Transmission pan, split hose, bad connection behind the radiator? It's too hard to answer without details.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    i had this problem not long after i got mine. got to the stage where it wouldnt go anywhere. turns out gasket was shagged, a service and it was as good as new
    Aug 2008
    Ok, i was just outside for a bit checking it out and it is leaking from the pan thingy between the exhaust pipes at the front with the bolts around the outside, so that must mean it is a seal or a gasket right? Would I be able to change it myself if it is? Here's a pic of where it is dripping out.
    [/IMG]
    And thanks for the offer Dave.
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    seal is shagged, go to autobarn or wherever and buy a 50$ trans servicing kit, change ya filter and gasket and such all at once
    SIR LS1
    the two ton go kart
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Yeah that looks like the transmission pan gasket is shagged, if you are going to change it yourself, make sure that you clean all the old gasket off, and when you tighten up the bolts, make sure that you tighten them up to the correct torque, if its too tight then you will warp the pan and gasket, and you will end up with the exact same problem that you have now.
    If you haven't got a Gregorys manual, go out and grab one, under the auto transmission section it will describe exactly what to do. It's also important to ensure that you put the correct amount of fluid back in if you do decide to service it yourself. I wouldn't be driving the car until you have atleast topped up the fluid, but you need to check the fluid when the car is warm, it has to be between the cross hatched area of the HOT part of the dipstick.
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    and degreaser and air gun..... give it a good clean out
    SIR LS1
    the two ton go kart
    Aug 2008
    Hmmm, this all sounds like it will be a pain to fix. My trans is already a bit jumpy so it might make sense to take it to a place that specialise in them and get the seal fixed and the trans properly checked over. Probably book it in this week hopefully. Does anyone know any places which are good for this near the Semaphore/Pt Adelaide area? I might try Nisscare, they are pretty good.
    And thanks everyone for the help.
    Dec 2005
    Glen Waverley VIC
    Depending on the colour of the fluid, it might be worthwhile getting the whole system flushed at a professional auto transmission place. It will cost more than a standard service, but it is definately worth it, and its a safe guard against further trouble down the track.
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    im near port adelaide mate, i can do your trans pan lol
    SIR LS1
    the two ton go kart
    Aug 2008
    ^That would be awesome, but i think i'll get a full service on the trans, get it flushed out, checked over etc. But thanks for the offer mate. If i run into problems with other bits on my car i'll definately keep you in mind as you live close.
    Thanks a alot everyone, looks like im back to driving the good old magna for a bit haha.
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    2003 VY S1 Acclaim
    Nov 2007
    i got mine done at my mechanic. u know the repco one (Port Adelaide Auto Repairs) in the port, its next to the medical centre on the road to the back of kmart. ive been taking my car there since i got it, full trans service was about $140ish. ive never had any problems with them, nice blokes. the kmart tyre and auto in the port is also very good ive found. dont go to profix, i took my magna there once when i had it, absolute tossers
  15. #15
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Is it better to buy the genuine service kit with the paper gasket or the repco one with the cork gasket ? oh , and wot about deep pans, is it worth buying a deep pan ? If i bought a deep pan, do i just need the deep pan filter kit or is there more ?
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The commodore V6 has a shallow pan - the genuine service kit should come with a cork/neoprene gasket and a filter to suit a shallow pan. Don't overtighten the pan bolts and you won't have any problems.
  17. #17
    greenacc's Avatar
    VE Berlina
    Jul 2008
    The VS V6 auto has a shallow pan as standard, but there is a deep pan option, which obviously has a larger oil capacity and has a longer filter neck so the pickup is deeper in the fluid to prevent it sucking air when driven hard. Whenever you go to holden to buy a service kit they ask you if it has the deep pan. I think the only difference for servicing is the longer filter , with same gasket. I'm considering if its worth buying a deep pan from a wrecker or holden and converting mine over , it sounds like a cheap mod. Anyone done this here?
  18. #18
    VX S2 Exec
    Sep 2008
  19. #19
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
  20. #20
    greenacc's Avatar
    VE Berlina
    Jul 2008
    yeah thats the one Zuicider. Mate of mine bought a new VS and complained to the dealer that the tranny was behaving strangely, and making a funny sound like shh shh shh, so the dealer apparently fitted a 'chuff kit ' ? which was basically a deep pan on the auto.
  21. #21
    Aug 2008
    Ok, so i got the car checked at Nisscare and the cork seal on the tranny sump plug had been overtightened a couple of times before and has now worn out, so i booked it in for a full trans service which is gonna cost around $125.
    Thanks everyone for the help, greatly appreciated.
  1. Leaking Fluid..
    By Lukie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2010, 02:06 PM
  2. Fluid leaking under Dashboard in VH
    By veeque92 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2006, 06:06 PM
  3. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  4. Leaking Tranmission Fluid
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2005, 02:48 PM
  5. Unexplained Leaking Of Trans/ps Fluid
    By ML3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 04:41 PM
