Results 1 to 9 of 9
Thread: VR berlina blowing black smoke.
    VR Berlina Series 2
    Sep 2008
    Default VR berlina blowing black smoke.
    When I start my VR berlina, black smoke comes out of the exhaust... like a fair bit of it, but only last for maybe... 10 seconds or so, but i still dont like it doing that.
    what could this possibly be causing this?
    i was thinking it could be the o2 censors? but could be mistaken.
    thanks.
    Dan.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Do a test for engine fault codes (how to section has a guide) then see where your at.
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    two bottles of stop smoke and sell it.....
    Joking...... I had a VS that did that it was the rings causing the grief.....
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Your injectors could be leaking overnight - this floods the combustion chambers with fuel and when the engine starts it burns off the excess fuel resulting in black smoke. Cheapest fix is a tin or two of injector cleaner.
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    its overfuelling by the sound of it like mine is ... is the car on gas at all ? mine is also hard to start
    SIR LS1
    the two ton go kart
    VR Berlina Series 2
    Sep 2008
    Quote Originally Posted by hako View Post
    It happens everytime I start the car, not just in the mornings.
    Quote Originally Posted by davecunno View Post
    Nope, its on petrol.
    It takes a few seconds to start.
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    yeah i know, mines petrol too but has a gas tune so its majorly out ....... does it stink like fuel when its running
    SIR LS1
    the two ton go kart
    VR Berlina Series 2
    Sep 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could still be the injectors leaking - try injector cleaner as a first cheap fix (alternatives will be more costly!)
  1. Vr :problem with car blowing out black smoke
    By mikapikapika in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2008, 09:44 PM
