Results 1 to 11 of 11
Thread: Extractors, Are they really worth it?
    SKNOT9 is offline All hope is gone
    VS series II Acclaim
    Feb 2007
    Lobethal, South Australia
    Default Extractors, Are they really worth it?
    Hi there. I have a 2.5 inch exhaust and CAI blah blah and i was wondering how much of a benifit i will actually get from extractors? Like for 500 dollars it doesnt seem all that worth it from what i have heard. I could be wrong, anyone willing to add their experiences?
    Jun 2005
    unless youre planning on doing work to your car engine wise, a lot of it, then no. not worth it
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    If you want a little more kick mid-top end then go for it but dont be expecting miracles, a slightly different exhaust note and a little more push (similar to a sports exhaust versus a stock exhaust) expect around 10-15 kilowatts at the wheels with a full exhaust setup & higher flowing filter (extractors n exhaust with a cold air induction/high flow filter element)
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    the stock manifold is decent, but good extractors will be better. Try and get some good secondhand ones from a wrecker , cos for say $150 the equation sounds a lot more appealing. Depends how you drive too, if you like to push it you will like extractors
    MEANVY's Avatar
    MEANVY is offline Donating Member
    VY Omega
    Aug 2008
    Darwin, NT
    They are worth it.
    Even just in a daily run about where you occasionally kick it in the guts. Great fun, and i think it's worth the bang for the buck personally
    There's plenty of room for all of God's creatures...right next to the potatos
    Mitch's Ex-police VY Commo
    Quote Originally Posted by VT SERIES II View Post
    if a stripper said it , it MUST be true!!!!
    .....I still think its dirty .....
    Jun 2005
    you'll notice SFA difference with them. $50-100 per kw doesnt really sound like bang for buck. spend the money on a tune, and a service, and youll probably get the same effect. any difference would be in your mind really
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    That depends how much power you have to start with
    I reckon the extractors are a total go-er.
    I definately noticed a difference in the note, performance and fuel economy of my vp manual v6 when I fitted mine! - went form like 450km/tank to about 500km/tank! and sounded heaps crispier and healthier!
    89 VN Exec, 94 VR SS
    Dec 2007
    Pacemaker seem the most popular as well probably the best for the average person
    VT
    Apr 2005
    QLD
    I think you should find out what they do and how they work before you say "I don't think they're worth it"....
    If you plan on doing any mods to your car, this is usually the first port of call.
    Extractors are called such because they aid in the removal of exhaust gas from the combustion chamber as the exhaust valve opens and the piston forces the gas out, keeping this gas velocity up means that with cam overlap (intake valve beginning to open as the exhaust valve closes) the exhaust gas leaving the cylinder pulls fuel air mixture into the cylinder through the inlet valve(otherwise known as 'scavenging'), effectively putting more fuel and air in compared to a standard manifold. This increases power, torque and economy in most cases and in some cases, decreases combustion chamber temperatures.
    There is a LOT more science in it than that, but that's the basics for you.
    IMO, they are worth it, even if you don't plan to mod your car any more, because in all the times i've fitted them to my car, you can notice the better economy on long trips if anything.
    Hope this helps.
    nick
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    well, they are a better replacement when u find the passenger side exhaust manifold cracked, every car ive had with cast iron headers have had that one cracked, and the same with my mates 2000 model vs ute
    JJ's VR's Avatar
    JJ's VR is offline VRHLDN
    VR 3.8lt Supercharged 163.8kW & VS sII HSV Senator
    May 2006
    Quote Originally Posted by VN_Luke View Post
    Yep, go for it! Very worthwhile, nothing to loose, something to gain
  1. Are Extractors Worth It?
    By VXWAGMAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2009, 10:00 PM
  2. Is it worth it???? Extractors???
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2007, 08:02 PM
  3. Is it worth it?
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2007, 10:58 AM
  4. HSV VS MALOO EXTRACTORS, will they fit my stato & is it worth it ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2006, 07:01 PM
  5. Wildcat extractors Vs Pacemaker extractors.
    By rob_phill in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2006, 09:05 PM
