G'day guys, my missus has just bought herself a VR berlina and the drivers side sunvisor bracket (the bit the sunvisor clips into to stop it from falling down) has broken.
Just wondering, do i need to pull the whole head lining off or is it a simple pull out and replace 5 minute job?
Thanks guys
If You're Not Touching The Walls, You're Not Driving Hard Enough.
Is Skaife, Is God.![]()
Thanks mate.
Don't spose you'd know how to take the front bar off too?
The alignment is slightly out and I promised her I'd have a go at fixing it for her.
Thanks mate, you've made my night !
I was stressing, couldn't find anything on the net about it.
does this sound right?
im sure if u adjust the 4 reo(reinforcment) bolts on the reo bar, behind the plastic bar which are larger than 10 ml and the 3 or 4 10 ml bolts on each side on the inside of the gaurd behind the indicator, u can leave yor lights and indicators in 4 a good adjustment?
