Results 1 to 15 of 15
Thread: Mystery Suspension Problem - Please Help!!!
    '97 Lexcen Wagon
    Sep 2007
    Perth, WA
    Unhappy Mystery Suspension Problem - Please Help!!!
    Hi guys,
    My VR's got some serious front-end suspension problems and we can't figure out what's causing it all.
    Struts, towers, shocks and springs are all in a really bad state but I'm not going to replace it all because the car's being traded soon so it's not worth it.
    Basically I need to know what exactly needs to be done to just make it drive straight. The 'symptoms' are:
    - For ages the steering wheel had to be turned almost 45 degrees to the left in order to drive straight
    - Then yesterday the wheel was sort of all of a sudden tilted to the right (but not as bad) but pulled really hard to the right and took a bit of effort to keep straight.
    - And in general there are all sorts of thuds and clunks and groans from the front end when turning full lock.
    So has anyone experienced this or know what the problem might be? It's been looked at by a few suspension people who each tell me its something different. As I said, I am aware the whole front-end suspension set up could do with a freshen up, but I'm hoping to narrow it down to replacing one or two things just to get it driving straight.
    Please let me know if anyone has any ideas!!!!
    Sami
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    sounds like its farked mate. Could be the bushes worn out causing play in the radius rods and control arms, stuffing up your alignment. Don't think worn shocks would do that.
    Could also be the rack is wearing out ? See what you can find at the wreckers if ya don't want to spend too much.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I can tell you that it's the shocks and strut tops that cause the clunking noise. Common for old worn front shocks. As for the rest, I actually suspect the rack has jumped a cog once or twice but I really don't know..
    WTB: mulberry VN interior parts
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Have you tried giving it a wheel alignment?
    Have a look at the tie rod end (I think its called). Can be found at the end of the steering rack control arm. See if there is any play at all. Its a ball joint type.
    Another one is the radius rod bushes at the end of the Z bar which bolts on the k-frame. (Front of it)
    Just to point out a few things.....
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by howepower View Post
    rotate your tyres it sounds like rubber to me
    haha yea ok
    Doesn't sound like it to me. Tell me how my tyres are going to change the steering by that much, literally overnight. That doesn't make any sense. (No they aren't flat.)
    It's my car, the thing has changed from 45deg left steer to go straight to slightly right to go straight.. don't feel like blowing 50 on a wheel alignment either if it'll just go stupid again within the week.
    VS Acclaim V6
    May 2005
    Quote Originally Posted by savage1987 View Post
    haha yea ok
    Well if you are not going try what other have suggested then whats the point of asking here?
    You said you are not going to do the wheel alignment then you never know if thats the cause of your problem.
    When it comes to solving problems, you need to eliminate things one at a time.
    I'm not trying to have a go at you.. just pointing it out.
    You might as well just leave as you are going to trade it in. Someone else will fix it.
    howepower's Avatar
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    Quote Originally Posted by AttaBoy View Post
    You said you are not going to do the wheel alignment then you never know if that going to be the cause of your problem.
    i agree
    anyway its whats called radial pull when the carcus of a tyre seperates it looks right but its not and geuss what rotating your tyres
    cost geuss what umm $0
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I haven't wheel aligned it, because I have SEEN the wheels change angle to each other. One day the right wheel pointed 10deg or so too far to the right. The next day it's completely different.
    The wheels have been pointing in physically different directions, and their directions have changed for NO REASON.
    Also I am not trading the car in, I'm trading it for a mate's car. If this front end is a simple fix then I will look after it.
    Next time I have access to the car and my tools at the same time I will swap the tyres around and see if it makes a difference. For now, for being a smartarse you can **** off out of this thread. IF rotating the tyres makes a difference I will eat my words.
    Sam
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the radius rod (Z bar) bush at the front - if they are really worn they allow one wheel to move backwards altering the alignment dramatically. Also same for the lower inner control arm bush. All can be bodgied up.
    Also may pay to look at the rear suspension bushes esp the panhard rod and upper control arm - if they are shagged they affect the steering.
    VS Acclaim V6
    May 2005
    Is the steering rack bolted tightly on the chassis? There are two bolts (I think) that holds it. Highly unlikely its the cause, but check it out.
    If the wheels are in different direction each time then I would assume the steering rack is the cause or a very worn down suspension bushes.
    Are you able to take a clear photo if it and post it up? Hard to tell without looking at it.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by hako View Post
    I'll have a look, those front bushes are pretty shagged (z-bar) I'll have a look at the inner control arm bushes next time I'm at the car and have a jack...
    Probably a while away yet.
    I wasn't aware that bushes could cause so much drama, maybe it's a simpler fix than I thought..
    Car's not at my place (miles away at fiancee's house) so bit tricky to do anything really.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Regular loud bang from front end suspension, wheel alignment changes.
    Rotated the tyres, still doing it
    Wheel alignment done after new front z-bar bushes installed, still doing it
    Check out the section in bold in post #16 in that thread I linked to, that's the problem as it is now.
    Any help appreciated
    Sam
  15. #15
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Fixed. Loose ball joint was to blame on the driver's side wheel. Has been loose since I got the car, getting progressively worse but now it should be all good.
  1. Mystery Noise
    By younglion in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2007, 01:47 PM
  2. Mystery box
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 09:18 PM
  3. suspension problem???
    By Rishy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2007, 08:54 AM
  4. No spark to 3 and 6,Mystery problem
    By Veneficus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2006, 04:07 PM
  5. Suspension Problem?
    By Infus10n in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 06:08 PM
