Hi Guys,
My son Rees recently purchased his pride and joy, a VS Statesman. All was going well till a week or so when the statey started to over heat and the thermatic fan would not engage and air con wouldn't work. He took it off to an auto elec and was told it was probably the condenser leaking and air con was out of gas, cost for repair and re-gas $450 uggh. I just want to know that my young statey driver is not getting ripped off coz of his age and lack of air con knowledge. If anyone can offer me some advice it would be great.
Rees' Mum
V6 or V8? The fans are independent of the airconditioning compressor (except that they are supposed to turn on when the airconditioning is turned on). I'd get them fixed first before worrying about possible problems with the compressor.
Hi it is a V6
That price seems pretty good however that may not fix the overheating problem as the fans should have come on as soon as the car got hot. I'd be more worried about fixing the overheating problem before worrying about the aircon - you can get a lot of help from this forum if your son wants to try fixing it himself and saving a lot of $$$$.
hey next thing i would be looking at is the thermostat and the fuse for the thermo fans as if the fuse for the fan is blown it will overheat and also stop the aircon from working
Homer: "for once in my life someone is calling me sir without (your making a scene)"
Hi Guys,
Thanks for your help, will let you know how we go
Worthwhile also checking temp sensor, as the thermo fans run through this circuit$15-$25 20 min job. Located behind alternator on the inlet manifold, 2 wire sensor plug.
Hi Guys,
picking up the Statey today, final cost $500. They tell me they have checked the fans and changed the relay and are working, so here is hoping. Thanks for all your advice.
Rees' Mum
