i keep getting code 63
both oxy sensors r new
code 63 lh oxygen sensor(o2)-no signal
any thoughts about it
7 snakes 4 kids 1 wife 1 ea falcon 1 vs dunny door
I got this when my plug to the sensor was unplugged after gearbox was swapped out :P
stupid me forgot to plug it back in,
if it is plugged in then I would take it back to where you got it from demanding a replacement
You probably need to clear those codes - disconnect the battery for 10 seconds minimum to wipe the codes memory then check the codes again - they should be gone.
If you don't clear the codes you will still get a code 63 as this code is locked in the ECU fault log till cleared according to my Gregorys.
now the next question what side is the lefthand side
standing facing the cars engine is left the drivers side ?or if u sit in the car the passanger side is left
whitch 1 is it ?
Left hand side is the passenger side. Did you try clearing the codes?
put another sensor in cleared codes still code 63 and now cam sensor code is coming up
could it be the ecu(computer thingie)?
about 2 blow up car lol
cam sensor is new to so whats the problem
was the ecu so ****ed off at least all the sensors r new as well
put a chip in it at the same time
Bloody cars
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
remove chip...sounds like you have a sinceya fault....
