hey guys i relly need some help the other day i replaced the cank angle sansor since it was on its way out stopping wen it got hot and fixed it but wen i first got it started again after hookin the battery back up it was idling a bit high then idled low and all fine for a minute then just started increasing its revs and missing its got code 12 that its ok but this has got me stuffedand it wont stop it sounds like theres nothin wromg with it once ii get it over 3 grand but wants to stall wen its bellow if i touch the throttle if any one can help with this be very appreciated
could be acouple of things, easiest to start with would be a jamming throttle cable or poorly adjusted cable. Next maybe check the throttle butterfly mechanism itself, see if it opens all the way, and snaps back to shut quickly. Could maybe even be IAC motor is a bit sticky on throttle body? Hey, it could even be the rotor veins on the balancer a bit out of whack on the air gap through crank angle sensor. There is a certain clearance spec there and the veins and rotors should not touch. Is the balancer tight? How is the condition of balancer? Any hair line cracks, chunks missing?
You might need to reset the ECU and IAC ? The new CAS could have confused the computer. This should have happened when you reconnected the battery, but might need to do it again ? Did you play with anything else under the bonnet ...
check all the electrical connections around the area you worked.
could be that you pulled some of the fuel line thingos off for the charcoal canister or a vacume hose?
yer mates got it all fixed ended up it was the cas it was faulty and giving wrong reading makin my engine rev up to 3 grand and back fireing
