hi guys im currently putting an ecco tech in to a vr i have the completer vs to take it out off we have the motor in the vs commputer in and i had to change 2 plugs on the vr main body harnes 1 is it has 2 wires comeing out off it purple and white and brown and the other has 5 wires but the vr has only 4
the 5 wire is a pink wire ok the problem i have got is the motor turns over we have spark if i spray fuel down the thottle body and i can get it to fire but i cant get it to run on the fuel by it self ok i have fuel pressure going down to it but it is like the injectors aint fireing i have checked for error codes i got 12 sytem ok and 31 theft deternt system but it had a blown fuse and replaced that i am still runing the vr body computer do u think it would help and would it work if i put the vs body computer in i might add the vr is a wagon exc and the vs is a sedan and is a aclaim if any one has done this or have come accros this could you please hellp i have been trying to sort this out for 2 days now and im ready to push it out the front and burn the thing
