Results 1 to 10 of 10
Thread: VQ statesman Wont start
    VP Commodore
    Nov 2006
    Default VQ statesman Wont start
    My VQ statesman wont start, It turns over but wont start suggesting fuel is not getting into the engine or the coil isnt sparking. Dont know much about theese cars can anyone suggest some basic things to check.
    And tell me where i can find the fuel line so i can disconnect it and see if fuel is reaching the engine.
    Also is it still safe to check if the coil works by putting metal into the end of the main plug from the coil and turning it to see if it sparks?
    Havnt worked on cars in a while and not ones of this year era.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Could be that the immobilizer isn't turning off. Does the security light flash when you are trying to start it. It could also be many other things.
    MY RIDE
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    my car did this to me this morning, 4:45 am and I drive my supervisor to work as he lost his lisence, so not good.
    I ignored the car and called the boss, let him know I was rooted and that his wife would ahve to drive us, got home went over to the car, tried again, still nothing, got dad to turn the key while I hit the fuel tank with my hand, VROOOOM, first shot and I got it, faulty fuel pump, give that a go maybe :P
    VP Commodore
    Nov 2006
    No, secruity light doesnt flash, im ganna try the immobilizer bypass trick now dont know how long it will take, doubt it will work thow. If it doesnt ganna have to find the fuel line and make sure fuel is getting to the engine.
    VP Commodore
    Nov 2006
    do you have a similar car to the VQ? because i have reason to belive my troubles are fuel pump related. ive had similar troubles before as in:
    i would park the car with about 15% fuel in it go to start it.. wouldnt start... dump 10 litres fuel in it starts....
    this time ive dumped 20 litres in the tank... might give kicking the tank a go.
    VP Commodore
    Nov 2006
    ive tryed to override the immobilizer by leaving the ignition on for an hour no luck... you can hear the fuel pump working when you turn the key....however i cant get any spark from the distrubutor.
    I tested this by getting a screw driver and shoving it into one of the spark plug leads and then grounding it did this at night with different ground sources no spark at all.... is there a better way to test this?
    went to check the points on the distributor itself and OMFG it could not have it it in a worst spot. Will try and have a look when its a bit lighter.
    Anyone out there offer any other advice? like maybe resetting the computer etc? thx.
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    VP Commodore
    Nov 2006
    Quote Originally Posted by howepower View Post
    spray aerostart in it while some one is cranking no fire it means no spark
    never heard of anyone doing that before.... what if i just used flammable deodarant
    VP Commodore
    Nov 2006
    Run a diag test by bridging port 5 with port 6 on the Diagnostic Connector
    got codes :
    12 = NO RPM signal
    31 = Theft Deterrent Signal Missing
    my key doesnt seem to let me change batterys... i find it hard to beleive that it would be my immobiliser but maybe... its the stock stanard one that came with all VQ statemans.. any else have any other ideas? thx.
    VP Commodore
    Nov 2006
    Quote Originally Posted by Meerkat View Post
    got codes :
    12 = NO RPM signal
    Correction: Just rest my computer by pulling the fuse for the engine in the box under the bonnet out for 5 mins.
    tryed to start my car didnt work.
    did the diagnostic test on the computer and only get code 12 not 31.
    12 = NO RPM signal.
    what could be the cause of this? besides the engine obviosuly not starting.
  1. statesman 5l wont start!! ecu maybe a problem??? need help asap!!!
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2010, 07:20 PM
  2. WB Statesman blue 308 motor wont start..
    By BOGANV8 in forum General
    Last Post: 03-08-2008, 04:52 PM
  3. VN wont start
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 11:59 AM
  4. HELP - Car Wont Start
    By fr3dd0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2006, 02:35 AM
  5. vn v6 wont start
    By prince_dj666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2005, 01:19 PM
