Results 1 to 5 of 5
Thread: vs engine fan
    alan smithy is offline alan smithy
    vs wagon
    Aug 2008
    footscray melb.
    Default vs engine fan
    hi all, have noticed that fan doesn,t come on with ignition. it starts when i let it idle for 5 minutes but by then the gauge is half way.shouldn,t be too worrying but i think it should come on earlier. any clues? thanks.
    XeKToReX's Avatar
    XeKToReX is offline Put it on credit!
    VK SL, VR Exec, VS Stato, VT Clubby #555
    May 2005
    N/E Melbourne, VIC
    you will notice it come on around half way, that is correct, theres no problem there!
    vs wagon
    Aug 2008
    footscray melb.
    ok. thanks for that. tried the codes before logging on. all ok. just thought it comes on with ignition. but every thing must be ok. thank you for your time.
    XeKToReX's Avatar
    May 2005
    N/E Melbourne, VIC
    no worries, the older style fans were run on the belt so they were running all the time, but your vs is controlled by the computer to come on when the engine reaches a certain temperature, sort of emulates driving, causes air to pass through the radiator to bring the temperature back down, then computer turns it off
    HRVATSKI_VOJNIK's Avatar
    HRVATSKI_VOJNIK is offline a.k.a KRIS
    VS Commodore V6
    Aug 2008
    Deer Park, Melbourne
    If you turn on the AC, the fan will come on
    i do it sometimes when i'm in start/stop traffic
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  3. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
