Results 1 to 12 of 12
Thread: Supper Low King Springs
    VS Executive V6 Auto
    Dec 2007
    Newcastle
    Default Supper Low King Springs
    Hey guys,
    I want to lower my VS Exec and have a few questions.
    My car has a solid rear axel and is completly stock expept for short Monroe GT gas rear shocks (p.n. 15-0166).
    I want to get supper low King Springs and was told by a guy at the local suspension place that they usually put super lows in the frount and ultra lows in the rear. What do people think about this???
    Also I want to put new frount struts in at the same time (to save pulling them out twice). A friend of mine has some standart struts he can sell me cheap (Monroe Sensatrac) can some one please let me know if standard hight struts will work with super lows of should I get shorter ones???
    Does anyone know how Sensatrac compare to GT Gas???
    Is it a good idea to get seccond hand shocks (they are in good condition)???
    Thanks
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I dont know what you mean by shorter struts?
    You can either get adjustable strut tops or shorter shocks.
    Shorter shocks are recommended but with superlows its entirely up to you.
    Dec 2007
    Newcastle
    Quote Originally Posted by Ozzie View Post
    Why 2 threads?
    I accedentally posted the first in the wrong forum. Sorry
    VN/VT
    Sep 2005
    SA
    you can get struts which are shorter to suit lower springs which i have used and would recomend you do this if your lowering a car
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by V-ahhh View Post
    I dont understand how it could be shorter?
    When the shorter spring and shock are installed into the strut it makes it shorter.
    Otherwise the control arm rod wouldnt fit
    VN/VT
    Sep 2005
    SA
    the strut its self is not shorter, but the shock inside the strut is why? well if you put shorter springs inside a standard strut there not going to be captive they will just be wobbling around loose.
    *edit when you purchase short stroke shocks for the front your buying the whole strut anyway im not aware of how you can just change the front shock and not the strut? correct me if im wrong*
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    you are corrected.
    you can buy shorter shocks and fit them to standard struts making the strut shorter.
    and also if you put a shorter spring in a standard strut with standard shocks it doesnt wobble around. it just compresses the standard shock.
    VN/VT
    Sep 2005
    SA
    fair enough, but doesnt that kind of defeat the point of having short stroke shocks? have you ever had a car with lowered springs and standard fronts? you can move the spring around freely because its not captive..hence the reason for having the lowered front struts...
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    the strut is only the bass of the spring and shock, the strup top goes onto that.
    the basic strut bass is always the same even if you buy a full kit the only difference is the spring and shock and also the top depending if you buy adjustable
    VT series II
    Mar 2006
    Hi guys,,
    can anyone answer this question please??
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    thats just how they do it I guess, imo ultras at the back will be pretty rough and whack the bump stops, even with good mid range shockies.
    I went super lows all round, standard height shocks at the front no movement of the spring, but had to get shorter shocks in the rear as when jacked up the rear spring could be removed :P
    Maybe talk to a few other suspension joints and get a few ideas.
  1. king springs help
    By Wadeo.. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2008, 02:42 PM
  2. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
  3. King Springs
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2007, 11:29 PM
  4. Fs: [vic] King Springs For Vs Irs
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 03-03-2007, 05:35 PM
  5. fe2 vs king springs
    By jarrod587 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2007, 11:47 PM
