Results 1 to 7 of 7
Thread: Extra kW
    VR V6 Manual
    Aug 2008
    Central Coast, N.S.W
    Default Extra kW
    i was going through my owners manual for a vr and it said that the 3.8L non irs had 130kW @ 4,800 RPM and the 3.8L irs had 132kW @ 4,800 RPM. why would independent rear suspension make a 2kW difference?
    VY S L67
    Nov 2007
    im thinking that either 1 is a 3.8 buick, and 1 the ecotec, or that the live-axle saps more power.
    (ie more rotating mass)
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    VR V6 Manual
    Aug 2008
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    As said, its 2kw who cares. Im fair sure its wrong anyway and no I do not care if its an owners manual
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    irs gripping better on dyno ? better fuel in irs test car .. irs is lighter than a live diff ... the live axled car tester was a fatass ?
    SIR LS1
    the two ton go kart
    VP Executive R-spec
    Jan 2005
    That's engine kw, flywheel power, it has nothing to do with the driveline and you'ld just be a typo or just a slight variation in two different tests. IRS takes roughly 6-8rwkw extra to power over a live axel (that's from a guy that swaped his engine from IRS car to a live axel and did nothing to it other than that between dyno runs)
  1. extra wires
    By pegg in forum Car Audio
    Last Post: 12-10-2008, 01:29 PM
  2. Extra Go....
    By Jenga73 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-11-2007, 04:21 PM
  3. would you like some extra dish with those?
    By V85000i in forum General
    Last Post: 29-10-2007, 06:13 PM
  4. turbos need extra oil changes
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-12-2006, 11:52 PM
  5. need extra
    By VG commodore ute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2005, 03:45 AM
