Results 1 to 12 of 12
Thread: Loss of power while turning right please help
    VS Executive S2 3.8lt V6 Ecotec
    Nov 2008
    Melbourne, Vic
    Default Loss of power while turning right please help
    Hi first time post on here hope you guys can help I have a VS V6 ecotech 4spd auto and have been having a problem which only seems to happen when i am turning right. I t is ok if i take i slow but if i try to take off with a bit of throttle and turning right I lose power and and a couple of times the engine has stalled. I have no problems in a straight line or turning left????? I thought maybe it had something to do with the battery/battery connections /terminals and replaced the terminals and resecured the battery but to my dissappointment the prolem was still there. It is really annoying me and would love somee suggestions or maybe some one has had the same problem? Thanks in advance for any suggestions.
    P.S. I have tested the comp for error codes and only get 12 which is system pass so no clues there.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    How much fuel is in the tank? When you corrner all the fuel goes to one side of the tank and the pumps got nothing to suck.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Nov 2008
    Melbourne, Vic
    Nah it does it on a full tank aswell thanks for the suggestion though` the fuel pump was changed about a year ago.
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Mine did this the day after the fuel pump got changed. I think its something to do with the return line?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd go with the fuel pump suggestion as well....maybe the return hose wasn't put on properly and has finally slipped off or whatever.
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    the baffles (swirl pot) in the tank could be stuffed may not be holding the petrol around the pump
    Nov 2008
    Melbourne, Vic
    Quote Originally Posted by howepower View Post
    there is a pressure switch on the steering rack if it fails it can do that
    I have recently replaced the power steering pump as the old one had ceased after the front seal went. Is there a way to check if the pressure switch on the steering rack is knackered?
    I am gonna take the tank out this weekend and make sure the return valve is secured and also gonna give the TB and IAC and good clean. If the problem persists after that i suppose maybe this pressure switch could be my problem.
    Anymore info on this switch would be appreciated (where to locate it, what it might cost to replace if it is gone and can i do it myself?)
    Cheers everyone who has replied so far.
    vs Executive
    Nov 2008
    hope sumone can help!! vs commodore, kept stalling then hard to start, put i new petrol pump, not sure how to re pressurize th petrol, as the car will turn over but will not start. The new pump is fairly loud, should i take out pump n re do, also does any one know of a site that shows th fuel sysytem, yes i am a female but being th only person in house that wants it fixed, plz help! thanking you whoever takes th time to read
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe you should check for logged codes as it sounds more like a CAS than a FP. Check the "how to" section of this forum for advice on how to check the codes (easy) and also replacing the fuel pump (did you put enough fuel in?).
    I have 4 daughters and they all fix their own cars - I've never seen any reason why they shouldn't/couldn't and they all have far more patience than I.
    Checking error codes VR/VS (Revised)
    VRII Acclaim
    Jul 2005
    Quote Originally Posted by hako View Post
    I wouldnt be advertising that hako. You will have guys ringing at all hours of the night wanting to talk to them!
    kathy browne, you didnt mention it, so just in case. Would be worth doing the fuel filter do. Probably not going to be the problem, but dont want to overlook the simple things.
    If the fuel pump is priming there is a very good chance fuel is reaching the engine. It is a fairly direct route to the injectors.
    I would start with hako's suggestion, checking for error codes. May give you the answer straight away. Otherwise you are either going to be missing spark or fuel, or it is flooding (too much fuel). We can help you test these if the error codes dont help.
    Nov 2008
    Melbourne, Vic
    Anymore info on the pressure switch on the power steering rack? I took tank out today and removed sender unit and ensured return line was fitted securely, which it was, and gave the throttle body and Idle air control a good clean but to no avail still having this problem of the car losing power, but only while turning right.
    Any info on how or if I can check/replace the pressure switch on the steering rack would be great. Otherwise I might have to give in and take it to a machanics.
    Cheers guys
  1. loss of power
    By 81_vh_holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-01-2007, 12:45 PM
  2. Loss of power
    By BLUE_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 11:23 PM
  3. what causes power loss
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 10:20 PM
  4. loss of power
    By rail in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 04:54 PM
  5. loss of power
    By VT2VEight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2005, 04:29 PM
