Results 1 to 7 of 7
Thread: VS battery light
    VY SS
    Aug 2004
    SE Victoria
    Default VS battery light
    Hi All,
    Why is the Battery light in my VS illuminated?
    Whats the trigger?
    Thnaks!
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    try checking the charge coming out of your alternator
    if its low maybe replace the regulator on the back of the alternator
    if its fine check the wiring from the alternator to your battery
    if its an ecotec theres a post at the top of the forum for a similar problem
    hope that helps
    VZ SV6
    Oct 2008
    Newcastle NSW
    Battery or alternator first port of call... bush mechanics prescribes a bang with a spanner on the alternator and see if it starts charging again. Is it only on at idle or goes out at higher RPM.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As the above posts - usually the brushes wear down and no longer touch the commutator/slip rings - quickly and easily inspected by removing the brush holder (which incorporates the regulator). Its located at the back of the alternator and retained by 2 flat head screws. A new regulator with brushes is about $50.
    Jun 2005
    check the brown wire coming off the positive battery terminal going towards your alternator. its a fusible link, so check it with a multimeter to make sure the wire still works.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VY SS
    Aug 2004
    SE Victoria
    alt is charging at 14.01V.
    Battery is of unknown condition. So could it be the battery?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    14.01 Vdc is perfect....there is a charge warning light wire that connects to the alt as well - goes into the regulator and is brown - maybe check that this is plugged in correctly. I think this turns the warning light on if volts from the alt are not higher than battery voltage and this normally happens if the alt has problems but yours seems to be putting out the correct charge. I'd also check condition of battery terminals.
  1. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  2. Battery light HELP
    By RUN41T in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2008, 10:21 AM
  3. battery light on??
    By vr5l5spd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2007, 11:46 AM
  4. battery light on & orange light on
    By smokey.29 in forum Electrical Wiring / Questions
    Last Post: 12-02-2007, 06:16 PM
  5. Battery Light
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2007, 09:03 AM
