Results 1 to 12 of 12
Thread: anyone know how to replace dash's lights?
    VT series II
    Mar 2006
    Default anyone know how to replace dash's lights?
    Hi guys,,
    i'm thinking about changing the colour of my dash's light to white or blue..
    does anyone know how to remove cluster? also, are there any backing plate behide the cluster to make the lights go green? or just the green lights behide the cluster?
    i'm getting blue or white LED lights soon
    LightningVP is offline Donating Member
    None
    Sep 2008
    I can, what state?
    As for the "backplate" yes that is green...the lights are white
    VT series II
    Mar 2006
    I'm on the Coast NSW
    if i'm getting the Blue LED lights and put them behide the Green 'backplate',, then there not gonna turn blue!!,, how can i get rid off those backplate??
    cheers
    None
    Sep 2008
    Mine are blue, and show as blue, my only problem are the pins are orange, which the blue doesn't go trhough..., best option would be to ask phreddy about how to get rid of the back plate.
    VT series II
    Mar 2006
    Quote Originally Posted by LightningVP View Post
    So, how did u do it? also, just sent him Pm too
    None
    Sep 2008
    Quote Originally Posted by nilprapai View Post
    I'm pretty sure there is a hot to somewhere, I'm not 100% on how a VR/VS dash comes out...But basically, once it's out the back looks like this and there are 4 globes for the main section (and about 50,000 at the bottom for the signal/warning ones) (the brown circle things in the pic), they twist out, you take the globe out and put new globe in holder, then twist back in
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    The globes used to light it up are a T10 globe, there are new LEDs out that are in a T10case n just fit up like the old bulbs but come in a heap of diff cols.
    There are sum that have a concave lens so the light gets spread further n u dont get the hot spots like with normal LEDS.
    I had sum they were ok on orig dash but once i got a white one they looked crap n went out n got sum CCFL tubes from jaycar/work n used them as they spread the light more evenly.
    ________________________________________
  8. Default
    How well does the dim function work with LED's? I was under the impression that they were basically on or off, very little difference in varying light intensities. Would be good to hear some real life experiences though.
    Quote Originally Posted by zai View Post
    I am not sutpid
    None
    Sep 2008
    Quote Originally Posted by levymetal View Post
    it doesn't....because the "dim" finction works on amps...and because the LEDs have low amps, pressing Dim doesn't drop the amps lower than what the LEDs take up...
    EDIT: But I have 2 small spot lights that I can use if I wanna turn headlights off
    VRII Acclaim
    Jul 2005
    The easiest way is to change the fascia. There a couple of sellers around, were some on ebay. You remove the instrument cluster and replace the fascia, you can have a different coloured lens, have some custom graphic put on there, a different colour fasica.
    Street Commodores Instructions & Example
    http://www.custom-house.com.au/
    http://cgi.ebay.com.au/ws/eBayISAPI....2BSI%26otn%3D4
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Just make sure you get the polarity correct on the LED or you'll have to remove the whole thing again and swap them I had to do it 3 times before I got them all working.
    This is my dash. Globes replaced with blue LED's and stock fascia plate.
    Jan 2005
    Oh, this should help with removing the dash surround...
    YouTube - Remove VR/VS commodore dash surround.
    Once the dash surround is removed, there are 2 (I think) screws holding the cluster in. Once they are removed, gently pull on the cluster to release it from the 'sockets'. I dunno how to describe them, but pic is below (the blue and orange things)
    Then, as lightning VP said, just untwist the bulb holders, remove the bulbs and chuck in the LED's. I just used the same LED's as used in parker globes.
    A bit brief, but it's been a while sinceI did it. Hope this helps.
  1. replace fan belt
    By creamy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2008, 10:31 AM
  2. does the green stuff on the back of dash's...........
    By Gus The Snail in forum General
    Last Post: 11-10-2007, 10:38 PM
  3. Pic's of clusters/dash's
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2007, 05:47 PM
  4. Replace fog lights with driving lights?
    By Cav in forum Electrical Wiring / Questions
    Last Post: 25-10-2006, 08:12 PM
  5. LEDs to replace dash lights??
    By Lexx in forum Electrical Wiring / Questions
    Last Post: 14-09-2005, 07:50 PM
