Results 1 to 7 of 7
Thread: vacuum gauge
    VR manual
    Jan 2008
    Default vacuum gauge
    where should the vacuum line from the gauge go to?
    ive tryed the thicker vacuum line running along the firewall
    it was wrong.
    and i just tryed one of the 2 lines running from the throttle body to the charcoal canister.
    anyone know where its meant to go?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Can you cut it into the vacuum line to the fuel pressure regulator with a T piece....this should be straight engine vacuum.
    VR manual
    Jan 2008
    oh really?
    it shouldnt effect idle or anything should it?
    isnt that line a bit big though?
    Jun 2005
    the big line you mentioned on the firewall should be the map sensor line. it should be right to use. why do you think it isnt?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VR manual
    Jan 2008
    no its not the MAP sensor line
    its one that goes from the throttle body into a t-junction and the pipe goes both ways
    Jun 2005
    if its coming from the throttle body, after the butterfly, then it should be fine. just connect it to the map sensor
    VR manual
    Jan 2008
    alright cheers
    will do it today
  1. Auto Gauge 2"/52mm Smoke Series Boost Gauge w/ FREE gauge cup
    By pepstar87 in forum Parts And Other Items For Sale
    Last Post: 16-05-2008, 01:16 PM
  2. vacuum gauge stoped working
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-11-2006, 06:47 PM
  3. vacuum Gauge
    By sexypete in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-03-2006, 12:03 PM
  4. Vacuum gauge
    By Dogmeat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-07-2005, 11:47 AM
  5. vacuum gauge not working
    By kooloo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-07-2005, 01:30 AM
