Results 1 to 7 of 7
Thread: motor oil leak
    VS commadore V6
    Mar 2007
    Default motor oil leak
    Hi all, this morning i noticed that i had some oil dripping onto my driveway so i had a look underneath my car & it seems to be dripping from my oil filter but can't see exactly were it is leaking from, i changed the oil a few months back, i remember that i must have over tightened the oil filter because i made a bit of a dent in the filter when tighten it up, could this have stuffed my filter up ? is there anywere near the filter were it could be leaking from and running down onto the filter ?
    appreciate any thoughts
    thanks
    Rony
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by Ron41 View Post
    thanks
    Rony
    Could be coming from the rocker covers and running down, or perhaps from the front crankshaft main seal, both our VS commodores did that here, it weeps out of there onto the sump and then drips down off that.
    Best idea is to degrease the whole engine, give it a good wash down and then check it again a few days later after driving some decent mileage... that way you will get a better idea on where the oil is coming from.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've had the same and found the oil filter had loosened off. Another time I found power steering oil had leaked from the PS reservoir, ran down the PS hose, dripped onto the filer and then dripped off the filter onto the road. By the time it hit the road it had changed colour from red to black so it had me stumped for a while.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by hako View Post
    Both things have and one is still happaning to me
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    can be the power steering pump leaking down onto the oil filter. See if there is oil on the top of the filter, or just on the bottom !!
    vs 96 acclaim
    Nov 2007
    i've had the exact same problem..happended twice both with ryco filters so i'm guessing they don't like to be overtightened and aren't overly strong..i ended up getting a genuine filter from holden which solved my problem, hope this helps
    VS commadore V6
    Mar 2007
    Thanks a lot guys, it turned out to be leaking from the oil filter itself, there was a fine crack in it that i must have done it myself when i tightened it up to much last time i changed it, i replace it this morning [ properly this time ] & let it run for a while to check for leaks and it was fine.
    thanks again everyone,
    Rony
  1. VS V6 oil leak
    By mcvk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2007, 03:34 PM
  2. Oil Leak
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 06:23 PM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. oil leak
    By drans_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 07:22 PM
  5. Oil leak
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 09:14 PM
