Results 1 to 20 of 20
Thread: VS climate control MODE Question.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Default VS climate control MODE Question.
    Hi all,
    I push my mode button to get the air to come out of the top vents no go.
    I slap the side of the console and it works.
    Is it the climate control unit or is there something behind it like a vaccum tap???
    How do I fix it??
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS l67 statesman
    Dec 2008
    sounds like the vacuum block is stuffed read the reply I gave rabbit heers
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Mine does the same and I use the same bang method to get it back.
    It is as vsl67 said the vacuum block porblem and the remedy is to replace it.
    I have bought my new one but as yet haven't had time to fit it.
    Holden part#92140248 solenoid vacuum about $100+.
    Cheers SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VS_Pete_1's Avatar
    Dec 2007
    Cheers guys
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I fitted the solenoid about 2 weeks ago and the AC has worked perfectly since, no more closing of the vents and have to bash the console to make it start working again.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Just spent 4 x 30+degC days on the road travelling between Sudney and the mid north coast and the AC performed faultlessly.
    Will post up a pic I found of the location of the solenoid when I get home from work.
    SW
    1998 VS Statesman 3.8 Supercharged
    Jan 2009
    Gold Coast
    hey i have the same problem, can you post that pic so i can replace mine, thanx
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The solenoid pack is located under the front of the heater box - basicly below the radio almost at the floor lever of the tranny hump
    and 3 Dangerous non ABS VN's
    NORTI's Avatar
    May 2004
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Norti, I have a spare good working solenoid block if you want. PM me if your interested.
    NORTI's Avatar
    May 2004
    hell yeah, not entirely sure thats the issue, but Id love to swap it out & test my theory!
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by NORTI View Post
    I have a spare in the shed (ready for the 89 sedan) if you want to drop in to my work.
    NORTI's Avatar
    May 2004
  15. #15
    88GreenVN's Avatar
    Jun 2006
    will it be the same as the VR?
    Got this setup out of a VS ... so yep think so.
  16. #16
    NORTI's Avatar
    May 2004
    awesome, Ill have to get Ben to drop in for me, Im on lates. What time you there til?
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Between 10 and 4 - I'll have the white VZ
  18. #18
    NORTI's Avatar
    May 2004
  19. #19
    VS Series II Supercharged Statesman
    Nov 2010
    Angry AirCon on a VS Statesman (not the VAC PAC)
    Quote Originally Posted by VS_Pete_1 View Post
    Hi all,
    How do I fix it??
    Guys, I am hoping a legend in here can help me.
    I have the problem where vents are pointed permanently to the floor.
    in current 35+ degree heat this is killing me and my kid.
    Holden have tested all cabin gear (AC Unit, VacPac, connections) and all is good.
    They say the vac hose in the engine bay may not be connected which is possible because I had LPG fitted by a shonk dealer during winter and have found many things NQR.
    Can anyone tell me (preferably with pics) where in the firewall AirCon vac hose comes out, and where on block/head/solenoid etc the bastard hose fits to?
    I am confident this is my problem because I saw several hoses left clamped off while the guy was installing the LPG.
    pwetty pwetty pweese be someone in here that knows this and can share it.
    I have the holden original VS SuperCharger supplement manual and it is as useless as tits on a bull to me for this.
  20. #20
    VS_Pete_1's Avatar
    Dec 2007
    This is the best I could do I hope it helps I didn`t pull this car apart but I think it will give you an idea.
    pics in order
    1. line comes into engine bay passenger side.
    2. runs along firewall.
    3. goes into cabin near heaterbox inlet/outlet pipes.
    4. tee piece must be the line ??????
    5. and they go on here.
    Good luck.
    Attached Thumbnails Attached Thumbnails VS climate control MODE Question.-vac-line-1.jpg   VS climate control MODE Question.-vac-line-2.jpg   VS climate control MODE Question.-vac-line-3-.jpg   VS climate control MODE Question.-vac-line-4.jpg   VS climate control MODE Question.-vac-line-5.jpg
  1. VS Climate Control
    By Dowling_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2008, 01:39 PM
  2. Climate Control
    By E_ri_k in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 10:58 PM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. VS Climate Control
    Last Post: 03-06-2004, 08:17 PM
  5. 98 vt climate control dumb question
    By skb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2004, 12:15 AM
