Results 1 to 4 of 4
Thread: Themo Fan Not Working,, Cause any Problems??
    VT series II
    Mar 2006
    Default Themo Fan Not Working,, Cause any Problems??
    Hi guys,,
    after driving the car (VS Ecotec) for 2 days without the Themo Fan working,, and the temp gauge is not working now, will this cause any damage to the engine? how can i fix the temp guage? where the sensor located?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    you need the thermo fan otherwise your motor will overheat in a short amount of time on a hottish, even mild day. could be the motor burnt out on the thermo, the switch could be faulty, or could be a fuse or relay.
    try turning the aircon on and wiggling the connections to see if its something simple.
    VT series II
    Mar 2006
    Thanks for the quick reply..
    just find out that the plug was loose !! pluged it back and the themo fan is working fine..
    but!!! i'm still worry about the car that been driven without the themo fan working for 2 days,, will there be any damage to the engine?
    304 Calais
    Aug 2007
    Up your mum
    you never know, how many trips did you make, how long for and did you notice any unuual smells, sounds etc? chances are you could pass it off as if it never happened but it COULD have done damage. just monitor it over the net week or 2 including oil/coolant colour, any problems resulting in lack of power and the like.
    Post back if there is but at this point in time i wouldnt worry yourself over nothing if its driving ok
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Themo fan trouble
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 10:04 AM
  3. VS /V6 themo fan ????
    By BUSTER1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2008, 08:44 AM
  4. twin themo fans to fit a VP 1992 radiator
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 08:14 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
