Results 1 to 12 of 12
Thread: How big can brakes go before changing booster and master
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Default How big can brakes go before changing booster and master
    Just a thought,some people in pre-VS commodores use a VS brake bits when they go to larger disc's and callipers.When any1 in a pre-VT upgrades to the VT onwards brakes,its best to use VT booster and master to avoid the sh!t brake pedal feel.So how big can brakes go into a VS before they need VT gear used.
    And one more thing,did the VS II V8's get a slight brake upgrade at all???
    WTB:VR/S HSV 250km/h speedo cluster
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    The vt brake upgrade has 2 pistons per front side versus the vn-vs having only 1 so i would imagine thats why the larger booster is needed, but dont quote me on that.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    i say if you're going to upgrade the discs and calipers, you might as well do the whole 'kit' and use the booster and master that work with them!
    i did the whole lot and they are sensational on the slightly lighter VS chassis
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    as much as it "may" work...brakes are something you do not want to stuff up
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The twin piston set up requires more fluid to be displaced, that is why the VT master cylinder is used, it has a 1" bore. Using the original master cylinder leads to excessive pedal stroke.
    Visit my Facebook page
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Not_An_Abba_Fan View Post
    don't the VT onwards M/C have a "fast fill" stepped 1 1/4" bore? the booster is also better. with the VS you screwed becasue the only ever came out with the 15/16" m/c, atleast on the earlier models you could upgrade from the 15/16" V6 m/c to the 1" V8 m/c on the same booster
    Body by Holden, Soul by Brock
    the Legend will live forever
    VX SS M6
    Jun 2005
    ive got vt calipers on mine and my pedal travel isnt excessive its perfectly fine.
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    My former best mate put VT brakes on his VS series 1 berlina(V6) and the pedal felt crap like the brakes didnt have enough bite.My car,almost exactly the same(only difference at all was mine is a V8,IRS and series 2) yet mine braked alot better with stock brakes.I heard some time ago that the VS II V8's have a brake upgrade from series 1,how true i dont know.Im also sure the the VS 5.7L GTS and Senator had twin piston callipers yet it wasnt the same as the VT brakes.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Yes some of the vs hsv's did have twin spot calipers and they are different from the vt version. Im pretty sure they are also finned like the standard single spots.
    Apr 2006
    Auckland NZ
    HSV would have offered brake upgrades. not sure what the HSV solution was for the VS booster and m/c. forthe VS holden went with the plastic fantastic booster and m/c setup. this was obviously a failure because they changed it again for the VT.
    Jun 2005
    so how about using a VN 1 inch m/c on a VR brake booster with VT calipers?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    No matter what brakes, std or HSV came on VS's they all had the same plastic booster and 7/8"fast fill master cyl (same style as VT but smaller ).
    I'm running VT HSV 330mm fronts and VN GrpA 280mm rears with the stock VS setup and all rubber lines replaced with braided ones and the brakes are great.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. Replies: 3
    Last Post: 27-10-2008, 08:47 PM
  2. changing to a VT booster + master cylinder
    By madrx3boy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2008, 09:11 AM
  3. WTB: VS Non ABS Brake Booster + Master Cyl
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2008, 06:35 PM
  4. WTB : VS V8 Master and Booster
    By XTC16 in forum Swap / Wanted to Buy / Trade
    Last Post: 27-07-2006, 06:03 PM
  5. will a vs v6 booster and master fit a vr v8
    By commy92 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 01:05 AM
