Results 1 to 8 of 8
Thread: Checking Errors + Rough Idle/Start
    Bella - VK Wagon
    Dec 2007
    Default Checking Errors + Rough Idle/Start
    Hey Guys,
    Tried to check for error codes today in my VS 3.8L, I placed the paperclip into pins 5 and 6 like the guide in the How-To section showed. However instaed of getting the usual 12 code first up, there are no dash lights at all when I put it in the ON Position. PS. I tried pushing the pin in further/less etc made no difference.
    Wanting to check to see if CAS/O2 Sensor is causing a problem, when the car is hot after I have driven it for a while it is hard to start, (poured cold water on the Crank and it kicks over fine), sounds like CAS?
    Cheers,
    Dean
    VR Executive '93' 6
    Feb 2008
    Northern Suburbs of Melbourne
    mate ur ment to turn the ignitor but not kicker it over.... all ur lights on ur dash should light up ... u use a wire for soildering when i check mine... also ull hear the fan turn on ...
    Bella - VK Wagon
    Dec 2007
    Quote Originally Posted by maco_butterfly View Post
    I understand that, and I didnt kick it over, I read the How-To and turned it so the usual lights come on, and u can hear the fuel pump kick in, however still no lights.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by D34N View Post
    You might be confusing dash lights with warning lights - its the latter which will be lit and the "check Engine" warning light will flash.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Is your "check Engine" bulb out not working mybe??
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS_Pete_1's Avatar
    Dec 2007
    Change the cas mate. Common fault.
    I didn`t get a code error and the car cut out at 60k/hr.
    Bella - VK Wagon
    Dec 2007
    Will get the CAS replaced in the next few days, I have had the Coil/Plugs/Leads etc replaced about 4 months ago cause it was misfiring beyond belief. that fixed the problem, but still idled and sounded rough as guts, So CAS is the next culprit.
    In regards to the engine light, it works when the pins arent bridged but as soon as the 5 and 6 pins are bridged, no warning (engine light) sequence comes on at all.... weird
    VS_Pete_1's Avatar
    Dec 2007
    Sorry Mate had to find my post please read.
    VS Wagon Engine Just Cuts Out
  1. VT Calais: Rough Idle/Flat Spots and Harder to Start?
    By Lord-Data in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2008, 07:38 PM
  2. Hard start, sounds awful, then erratic, rough idle.
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2008, 07:09 PM
  3. rough idle on start up
    By metalfossil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2007, 01:06 PM
  4. Rough idle
    By robbo82 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2006, 09:18 AM
  5. rough idle on start
    By vs-s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2005, 12:43 PM
