Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: VR / VS Ignition coil replacement.......
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default VR / VS Ignition coil replacement.......
    Ok guys, when i manage to source an ignition coil for my VS Senator i'll obviosuly need to replace it.
    How the hell is it done? Never done it before...... Obviously it's a 304 being a Senator
    6leeta is offline Banned
    GREEN VE SS
    Nov 2008
    Its easiest to remove the engine covers, remove the distributor cap, then you will have enough room to fit your hand and a spanner down there, its as simple as removing the bracket the coil attaches to then a coil lead and power/earth leads many many people will tell you that you can reach it without removing anything, but these people must have the girlish arms in the world as i could never manage it.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I suggest you disconnect they battery first i'd hate to get zapped by one of them
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    GREEN VE SS
    Nov 2008
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Sweet thanks dude ^^^, as i am getting a cylinder shaped coil, i'll have to mount the bracket it comes with somewhere.
    Jun 2005
    anyone got a photo of where its meant to be? i need to find a decent place to put mine
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    It sits right behind the back of the inlet manifold. I had a decent look yesterday, it's going to be a bitch of a job to undo everything and mount this new cylinder coil i have.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    If it's a cylinder shaped coil you have the incorrect one, unless you are installing a non-Bosch equivalent.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    I was told that it would work but not perform as good as the square black one........
    I was under the impression it would still provide spark and get her started, it just won't perform as good as the black square Bosch coil.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Jun 2005
    cobez. this is where mine is for now. cable ties FTW. there was some little piece of metal there which is holding in place. it will do for now until i get a better coil. youll have to extend the wires though, and use a longer spark lead
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Extend the wires? What wires? This coil i have just has the male head on it for a lead.........
    I guess i'll leave the busted one on there for now, pull the lead off of it, hook it to the new one and bang hopefully she is sweet.
    Jun 2005
    you dont have the two nuts on it for a positive and negative wire? see those in my photo? on either side of the lead
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
  15. #15
    Jun 2005
    nah they go into the loom and go somewhere. not sure where though. hooking up to battery is a bad idea
  16. #16
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Fark this is getting annoying. I didn't know **** about a loom i thought i was just plug the lead in and sweet as a nut.
    Wanna do mine for me? I'll give ya $50 lol.
  17. #17
    GREEN VE SS
    Nov 2008
    The wires dont need to be extended that long, just make sure you use the proper connectors and use electrical tape to seal off the connectors metal surface, also tape the wires neatly out of the way so there not touching any components that are going to heat up. People who do this modification usually secure the coil off onto the passenger side strut tower & has 2 advantages 1- its easy to replace or work on in the future and 2- your giving the coil a bit more life versus the old one as its not directly near any heat source like they are from the factory.
    The cylinder shaped coil with the condenser hanging off the side is actually what came out standard on most of the efi 5 litres, if not all of them. It wont make a difference if its in good condition versus the bosch square type in fact even today the cylinder shaped coil is still used on performance cars using the grp a manifold, to keep the original look although they get them chromed to look that little bit better. People will only say there not as good as the newer bosch square coil because when it gets replaced in this day & age its already half cactus, buy a new one and its just as good as the newer style coil.
    Id go for a msd blaster series coil which pumps out more juice than both the cylinder shaped and newer style stock replacement coil stuff the standard replacement parts
  18. #18
    car
    Jul 2006
    greensy, melb
    go the msd one's, i got a high vibration one and it works great and being high vibration should last a long time. also go to autobarn and get a longer lead to suit, they are only $5
    NEW MSD HIGH VIBRATION BLASTER IGNITION COIL - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 02-Dec-08 19:49:15 AEDST)
    pic of where i put mine
    Attached Thumbnails Attached Thumbnails VR / VS Ignition coil replacement.......-rimg0483.jpg
    "A life lived in fear is a life half lived"
  19. #19
    Oct 2007
    supercheap auto / autobarn / bursons / repco etc will have a replacement coil i put mine in the same spot as the one depicted above as the factory location is just plain stupid
  20. #20
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    If you do manage to remove the old coil, never EVER [EVER] try and put one back in the original spot. Who ever designed this, or even allowed it to go into production should have been shot! In fact why even try to remove the old one? Leave the damn thing there and just extend [yep not easy] the two cables from it to the new one, where ever you decide to mount it. Some of the pictures provided should be enough to give you a fair idea.
    One cable is power and the other is from the ignition module. Then just run a slightly longer HT lead back to the distributor. Sweet!
    I just replaced the vacuum line between the brake booster and intake manifold. What a pain in the rear! Why would anyone put the manifold vaccum port in that location, perhaps the same dumb arse designer that also put the coil back there !
  21. #21
    GREEN VE SS
    Nov 2008
    That location of the coil was the same for all commodore v8's from vb, they simply must of left it in its place without bothering to replace it, on carby models it is easy as to replace it was just the introduction of the new inlet manifold which made the job an absolute bitch, but hey hard tasks mean more work for mechanics, thats was probably on their mind
  22. #22
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Yeah i am having another one fitted friday while i am at work, it's one of the flat square shaped ones, then i am planning on buying one of the MSD Blaster ones, or an ice ignition kit (coil, lead, ignition module etc).
  23. #23
    Jun 2005
    ill take your square one once you upgrade to msd
  24. #24
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    No worries man. I'm looking into either "Ice" or "Scorcher" gear. Leaning towards "Ice" coil and ignition module....
  25. #25
    VS Clubsport series I, VY II R8 Clubsport
    Jan 2008
    Sunbury, Victoria
    My VS Clubby is missing quite badly from 2500 RPM upwards and under load as well. It is worse when the weather is hot or after driving for 1/2 hour.
    The car also feels like it is constantly down on power but maybe thats me dreaming??
    Has anyone experienced this as I believe it may be my coil but arent 100% sure??
    It looks like a few of you have replaced coils and I was wondering if anyone had seen any of these symptoms?
  1. VN S1 Ignition Coil OHM Results....
    By shmickmik in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2011, 11:53 AM
  2. Question on ignition coil
    By snowman12 in forum Electrical Wiring / Questions
    Last Post: 23-10-2009, 08:40 PM
  3. MSD Ignition Coil
    By ThongyVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 09:33 PM
  4. Fitting VL ignition coil to an MG
    By bezz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-12-2006, 11:42 PM
  5. Test VT Ignition Coil
    By daffyy30 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 07:30 PM
