Results 1 to 6 of 6
Thread: Air Bag warning light after dash removal..
    VS III S/C 50th Statesman
    Apr 2008
    Default Air Bag warning light after dash removal..
    Yeah i know theres heaps of these posts about the airbag warning light staying on but nothing that was similar to my situation. Either way I'll call into Holden or electrician in the morning to get reset hopefully.
    Anyway, I had my gauge cluster out to change a few faulty globes and now the air bag light stays on, or rather it goes off for half a second then comes back on. I removed again to check for shorted contacts and globe but all seems correct but light still on. Any ideas with this one, does it normally require resetting after the dash has been apart? I haven't had the wheel or anything related to it apart.
    cheers,
    Ben
    cammed Vx ss m6
    Sep 2006
    Quote Originally Posted by Aus78Formula View Post
    cheers,
    Ben
    i had mine apart but i took my battery off first and the airbag hasnt come on. Anything to do with with eletrical things on the car i take the battery off just incase
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the ignition is turned on a fault will be set....this happens when people turn ingition on to listen to the radio whilst the dash is removed. Can only be reset by an elec or Holden.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Apr 2008
    Quote Originally Posted by hako View Post
    Um yeah that was me not so much the radio but different switches and lights to test as I went along checking for loose connections....oops
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Live and learn mate
    I have learn the hard way all my life
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. fuel warning dash light
    By JT090 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2008, 12:15 PM
  2. VS Dash Warning Light
    By jp7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 08:48 PM
  3. Dash warning light probs....
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2006, 04:08 PM
  4. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
