Results 1 to 5 of 5
Thread: VR V6 manual conversion
    V6 VR acclaim
    Jul 2008
    Scone, NSW
    Default VR V6 manual conversion
    im in need of all knowledge about a manual conersion for a 1994 VR V6 sedan.
    im wanting to undertake this task but i dont know enough about it and i have been getting hodge podge info from lots of unreliabe sourses.
    from what i have gathered, i will need:
    a T5 box (which are all the same?)
    a new computer,
    new drive shaft?
    new cross member for the box mount.
    i can get hold of everything required for the conversion for a very good price, but what i also need to know is if there is anything else i may need. and also info about the clutch. is the clutch pedal hole and mount points already marked in the firewall, or do i have to measure them off another body?
    is there any nasty suprises i should expect when i start doin the swap, or after its done? if this works out then i will be inquiring about problems when turboing
    thanks for any help.
    Jarrod
    If it aint broke, dont fix it.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    t5 box was found in fords and holdens alike, with different gear ratios, reconditioned ecus cover both manual and auto
    only need a yoke for the end of the tailshaft
    cross member is the same
    pedal box bolts straight in
    and the floor shift plate is same shape as the auto one
    good luck in finding a fly wheel i sold my last one for 450
    Haydz's Avatar
    Haydz is offline Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    V6 VR acclaim
    Jul 2008
    Scone, NSW
    thanks guys. i can get absolutely everything, including the manual center console for $350.
    V6 VR acclaim
    Jul 2008
    Scone, NSW
    i read through that how to do. very helpful. answered some questions. but i still need to know if the holes that need to be cut for the cluch are marked or not. from what i read there, it sounds as if i wont need to change the computer at all, just fiddle with some wiring, is that right?
  1. VP V6 Manual Conversion
    By bad benny in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2009, 08:52 PM
  2. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  3. manual conversion to vp 5lt
    By GMSSVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 07:24 PM
  4. BW Manual Conversion to VS
    By brenz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2006, 08:09 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
