My Climate control is not turning on anymore...I've check fuses and relays and wiring but seems all fine. The lights show up on it when lights are on but just wont turn on. Is it the module?
Yeah swapped relay over...Pulled the module apart and also tested wiring...getting 12v+ on blue wire and small amounts on the others...really don't see it being the wring and also the lights work in it.
Okay received another module but still not turning on.The lights work in it but nothing else. I currently have the whole dash out and all the wiring seems good. Also tested for power and it's getting power. I'm stuck with ideas...
BCM or ECM stuffed??
Reputation given to anyone that solves this.
FIXED!!!!!!!! It was the Warning Lamp Check Relay believe it or not. Who would of thought! The ignition relay needs to complete the circuit with the Check Lamp Relay for Fuse 9 which is for the climate control to get power I think. YAY! Wiring diagrams are great aren't they! Now I need to put the whole dash back, How fun.
oh the joy of pulling your car apart for nothing ,something I know about too well
I think we should sticky the climate control relay problem. Its very common, even when i was getting mine re-gassed recently the auto-elec said its in their top 10 common electrical issues for VR-VS
It's also a curvy issue because of the warning lamp relay.
Hi brothers! My car's climate control has the same problem, so could anyone help me to solve this problem. Please repy soon. Thanks brother!
have you tried the above method?
using a teat lamp or multimeter to check voltage?
changing fuses and relays?
The search function: try it people it actually works. heres proof
http://forums.justcommodores.com.au/vr-vs-holden-commodore-1993-1997/190851-thanks-heaps.html
Vr/Vs Commodore code checking
http://forums.justcommodores.com.au/...s-revised.html
I already tested the power, it is still ok. When i read Chirpstr's post, i think the problem is warning lamp relay as he said, but i don't know where it is and how can I fix it, if brother know how to do, please tell me.
Additionally, I removed the unit, clean the electrical pins, even tried with the second hand climate control unit, but it still works unstable. In the today afternoon, when I turned the car key on, it was working, but then I start the car, it didn't work. I really tired with the climate control because I've just changed the new compressor with $1000. Please help me to fix it. Thanks brothers.
