Results 1 to 9 of 9
Thread: windscreen stalk replacing with one from berlina
    Vr acclaim
    Nov 2008
    Default windscreen stalk replacing with one from berlina
    hi guys,
    I have a windscreen washer / wiper stalk out of a vr calais it has the variable wiper speed , I was wondering if you need to have a wireing harness as well cause it does not seem to be a plug and play fit to the executive
    VS Commodore Omega
    Apr 2005
    I am also curious about this, on my shortlist of wanted upgrades is a high model wiper stalk but no idea if it would work properly or not without additional parts from a high model.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I think it would require a BCM upgrade as with the VT-VX.
    MY RIDE
    VRII Acclaim
    Jul 2005
    The variable wipers depend on a signal that relates to the speed. Obviously this isnt going to be setup in a low series model.
    VY Wiper switch -convert to variable intermittant
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    hey guys yeah i fitted the berlina/calais variable speed stalk into mine and there is another wire that needs to be plugged in. also you need a High series BCM to make it work, i have the bcm (not fitted yet) and havent had a look at where the wire goes to yet but its definately on my to do list. as soon as i get a chance i will have a look and let u guys know.
    How To - Fix Reverse Lights For Free!
    http://forums.justcommodores.com.au/...commodore.html
    Jun 2005
    dont you need to change keys if you swap bcms? seems like a lot of effort just to get your wipers to change speed
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VS Commodore Omega
    Apr 2005
    Quote Originally Posted by stocky View Post
    True that, I guess it's not a modification for the faint of heart - though with a new BCM there's even more things which can be done like remote boot release on the keys and ... nope, I can't think of anything else
    Damnit I should have just bought an Acclaim+.
    Series III CV8 & VS Acclaim
    Jan 2009
    In a House
    Installing the high series BCM requires changing over the loom as well as the pin positions are different from low to high.
    The BCM will also need to be programed to work with the engine management system so you can start the motor but you can retain you key blades.
    Shambos Ride! Check it out!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Quote Originally Posted by VS Omega View Post
    Acclaims don't have variable wipers.
  1. Need help replacing VT indicator stalk
    By ford6779 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2008, 01:00 AM
  2. Replacing Indicator Stalk
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2007, 10:50 AM
  3. Air Con Evaporator needs replacing VR Berlina
    By vix350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2007, 09:07 PM
  4. replacing battery on a vx berlina,computer questions
    By warrick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2007, 05:31 PM
  5. Replacing the battery in a VS Berlina.
    By Hytes in forum Electrical Wiring / Questions
    Last Post: 21-04-2005, 07:11 PM
