Results 1 to 2 of 2
Thread: VS Series II Tensioner Pulley dimensions
    Nov 2007
    Default VS Series II Tensioner Pulley dimensions
    I was told today that I have the wrong tensioner pulley on my 96 VS series II commodore. My partner has the same car and the pulley is the same width - 76mm, but his appears to be 2mm difference in thickness.
    Is there more than 1 pulley size for this series?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There are more than one brand of after-market pulley available - mine is pressed steel with a replaceable bearing but the original was hard plastic and probably slightly different on width across the pulley face. As long as it bolts up OK and the belt sits central then it should be alright I'd imagine.
  1. Removing tensioner Pulley on VP
    By namreks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2009, 11:38 AM
  2. Tensioner pulley
    By matty193 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2009, 06:26 PM
  3. tensioner pulley
    By timmy_317 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2008, 10:08 PM
  4. Tensioner Pulley ??
    By DaveSch in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2007, 03:01 PM
  5. VS V6 Tensioner Pulley Bearing P/N° Please
    By c172skyhawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2006, 07:39 PM
