Results 1 to 11 of 11
Thread: removal of side kick panel
    HRVATSKI_VOJNIK's Avatar
    HRVATSKI_VOJNIK is offline a.k.a KRIS
    VS Commodore V6
    Aug 2008
    Deer Park, Melbourne
    Default removal of side kick panel
    Hey folks,
    I'm planing to repaint the kick panels
    after looking at my workshop manual (max ellery) which barely helped me with 3 steps which didn't make much sense
    so i need some advice with removing the side kick and side "panels" (the things on the side of the driver and passenger seats which the cables run thought the car. they sit under the doors)
    not sure what their called
    if there's a thread on this already, can you post the link
    thanks
    LightningVP is offline Donating Member
    None
    Sep 2008
    Looking at this picture...
    If you mean the panel with the switches, if VS is similar to VP then open the fuse section and there is one screw in there, and 2 other screws where the door closes.
    OR is you mean the part behind where my neon is, then there should be 3 screws just behind the fuse box (looking at the pic, my neons are sitting on those 3 screws) and there is on at the back holding it to the firewall/carpet, same for the passenger side
    VS Commodore V6
    Aug 2008
    Quote Originally Posted by LightningVP View Post
    i meant the panel right of the accelerator pedal
    Jun 2005
    pull it....
    grab it on the bottom, tilting the bottom towards you and they come out easy
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    None
    Sep 2008
    Quote Originally Posted by HRVATSKI_VOJNIK View Post
    there may be one screw in the right back corner, or at the top where it meets with the black panel above pedals, once they are off, then yeah it just pulls off
    VS Commodore V6
    Aug 2008
    here's a pic which should help clear things up abit
    i want to remove (1 side kick) and (2 lower side panel, but i'm guessing i'll have to remove the whole lower panel 2+3)
    well, i hope that cleared things up
    Jun 2005
    you know the speakers are meant to go behind the plastic grill on the door pod right?
    VS Commodore V6
    Aug 2008
    Quote Originally Posted by stocky View Post
    can't i spice things up abit?
    None
    Sep 2008
    Ok...
    1) I explained before, there should/might be 1 or 2 screws at the top of that panel.
    2 & 3) That is one piece, that rubber bit running down the middle pulls out, then you looking into where the rubber bit was you will see clips, get a flat screw driver and put it under the plastic (from inside the car, facing outside) the push the clip in (I would reccomend just pulling the plastic up with force as you can break those clips)
    VP Executive R-spec
    Jan 2005
    If you are tough you can squeeze the scuff plate and the clip comes out of the sill, that's how I do it and I have done that alot :0 to get at ecus
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Quote Originally Posted by greenfoam View Post
    LMAO, snap
  1. Black box, drivers kick panel...BCM?
    By Chirpstr in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-05-2008, 10:25 PM
  2. rear door panel removal on berlina series II 2000
    By joeyandhisVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2006, 04:00 PM
  3. instrument panel removal/new dash lights?
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 11:51 PM
  4. rear quarter panel window removal
    By commodorewannabe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 09:47 PM
