hi all im new here.....
i need some help with the level 3 dash upgrade from thoes who know and or have done the conversion.
i have the dash and mode switch on there way but no wiring yet, im just wondering what is needed and what needs to be done.
i am a quillifyed mechanic and i do know what im doing but need to know how to do it. and if im successful i might even wright up a tech article.
its going in a vr equipe 1995 series 2 and currently has the std dash.
It will plug straight into the original plugs in the back same as the original one would and the analogue dials will go
how i got the digital part going youll need the plug on the bottom and i just looked at the writing next to the plug where it has a number and what the wire goes to then went and joined them to the matching wire in the original loom
theres a yellow/black wire labeled eff and that one goes to the yellow/black wire coming out of the ecu and also the bottom plug joins to the mode switch.
also just watch out what green wire you connect the temp sensor to because i got mine on the wrong one and the temp light kept beeping and coming on and theres a couple of green wires down there
its pretty simple and all the wires should colour match onto the original loom
hope that helps
Federation
Against
Rotary
Tossers
so basicley i need the loom to go with the dash and patch it in, thought so, ill have to source a loom to suit
Yea pretty much, its pretty easy to work out and looks heaps cooler afterwards
Federation
Against
Rotary
Tossers
just put the dash in and noticed one thing, there is no chimes as in handbrake and low fuel, did series 1 calais or statesman have this function. my series 2 vr one did and it was quite good to an extent.
the only other thing i havnt done yet is the lcd bits i havnt wired them in, so i have no odo etc. does the chime on the level 3 dash go through that part of the dash?.
also i have the wiring lume here but far too lazy at the moment to put it in, i thinkin its a weekend job
This may help
vs dash upgrade
and here
Tripin'...
and 3 Dangerous non ABS VN's
thanks but that dosnt realy confirm is the vr series 1 calais/statesman dash has low fuel and hand brake chimes.......
not a big problem but would be nice
The chimes were in the VP/VQ and on I thought
thats what i wanted to here thanks i know the std dash, they brought it in on s2 vr but i wasnt shure about the berlina calais and statesman caprice., dash's
thanks
I know they have a low fuel chime, I'll try the handbrake tommorrow and let you know as I haven't heard that one yet.
i can't say i have ever heard the handbrake one hey:P lol
If Barbie's so popular, why do you have to buy all her friends?
simmaler chime to the low fuel but diffrent hz's i know my s2 vr equipe and my parents old vr acclaim s2 had this but this was also on the level 2 dash not 3.
just an update i finally did the conversion propley and yes everything works a treat.
bit of a pain in the ass getting the dash pad off but got it in the end.
took all up 3 to 4 hours thats including soldering and stuffing around with the stero etc.
looks 100% better and all functions work correctly
now i just need to drive the ting so the dash can calculate everyting correctly.
and yes both low fuel and handbrake chims (hand brake on at approx 20km/h) work cruise control works etc
a big thank you too all who have helped me out i know i was a big pain in the ass but thankyou thankyou all....
just another quick question, is there ment to be a light on the mode switch at all because when i drive at night i got nothing. also there was a extra wire on the lume that didnt go anywhere according to the wiring digrams could this be the light wire? or is me globe just blown?
what was the colour of the extra wire? i have a black and yellow one coming from there going nowhere and doesnt seem to change anything.
as long as the brown wire is hooked up to the correct one the lights should work, being 2nd hand itd be a blown bulb most likely
Federation
Against
Rotary
Tossers
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
does anyone have a pic of one of these dashes? iv never heard of them
