What does this mean
The red symbol your describing sounds like the brake warning light (blown globe). Check to see if all your brake lights and tail lights are working properly.
Originally Posted by davway
get it looked at asap... abs light is never a good sign... is brake spongey ... or does car pull up ok... what are your pads like atm and is your brake fluid low
SIR LS1
the two ton go kart
well one break light is out so that explains the red light but the abs light could that mean i have low pads
yea well my car has been going to brenton mechanical i will see if it happens after i get my new rotors and pads on friday
do a search for "ABS error codes"
there is a HOWTO here somewhere describing how to do it all, check the fuse too, oh wait actually I think the light stays off if you pull the fuse, but not a good idea :P
