Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Super lows put more pressure on steering rack true or not
    96 VS & 5spd VT 5.0L VX Clubsport lookalike
    Jun 2008
    Port Macquarie/Newcastle, NSW
    Default Super lows put more pressure on steering rack true or not
    I was talking to mechanics this arvo whilst getting my pink slip done and they believe putting super lows in creates more pressure on the steering rack and link pins and a few other things I cannot remember that will leave me with constant problems with the car later down the track... can anyone tell me if theyre full of ****? I was keen on super lows but maybe ill just use the SS lip kit to give it a lower look instead and keep my FE2 height...
    -darren
    Jun 2008
    Jun 2005
    put the right shocks in and you should be fine
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Jun 2008
    O.k so for a proper job I obviously need the coils and shocks ... what else?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Get sum lowered Springs, Sum new Shorter Shocks for ur model, sum new bump stops wouldnt go a stray either.
    And thats it.
    Rip the old onse out, put in the newies.
    You mite have to get a rattle gun onto ya bolt for the shocks on the strut tower, mine kept twisting n wouldnt undo until i got rattle gun onto it
    ________________________________________
    VT
    Apr 2005
    QLD
    Can't put any more 'strain' on it as you are keeping the same suspension travel arc.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    i have had super lows in mine for over a year, and had SSL for 3 years prior to that..
    had to replace both rack ends once, and one is getting a little sloppy again.
    haven't heard anyone have the same problems... but, then again, not many would know how to test them properly.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    naaar aslong as u do a prober job of it u will be right and dont cut corners, shox springz n ****
    VT
    Apr 2005
    QLD
    Quote Originally Posted by REV-231 View Post
    If the suspension geometry was changed, then it would be cause for concern as the rack ends could bind up through suspension travel arc. The ball joints in your rack ends may wear a little more, but I see nothing detrimental to putting the lower springs in.
    Jun 2008
    Jun 2008
    How do you mean sloppy? Not as responsive to turn or what?
    Jun 2008
    Quote Originally Posted by VT-565 View Post
    Yeah neither can I and so many people do lower their cars... hence why I was so skeptical at what they told me
    GTP 85's Avatar
    Aug 2006
    no im not implying it being detrimental... just putting forth what i had discovered from carefully observing the wear on the rack ends.
    The front end of mine gets totally checked for alignment every time i touch the susp. so im not neglecting anything. Its just something unusual that i observed
  15. #15
    GTP 85's Avatar
    Aug 2006
    Quote Originally Posted by dbarnes View Post
    just sloppy as in the ball joint in the rack ends loosen up. when i say 'slop' its a little bit of movement. enough to alter the toe fractionally.
    If you dont test it by hand you would never know.. till the car starts to wander under brakes lol
    The guys who do the Roadies here in S.A showed me
  16. #16
    Jun 2008
    Fair enough. Well Jax have told me everything is "tight" at the moment under there so I'll go for the super lows but done properly and just keep an eye on everything from there on.
    Thanks alot for all the inputs guys
  17. #17
    Jun 2008
  18. #18
    GTP 85's Avatar
    Aug 2006
    You will be ok.. cars inevitably wear parts out so i wouldnt worry too much. just keep an eye on tyre wear thats a good gauge
    they are called "rack ends" about $100 each i think they were..
  19. #19
    Jun 2008
    Ah ok I was expecting more thats a relief.
    Yeah I will keep an eye on the tyres once I have put them in thanks alot
  20. #20
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Tie rod ends should only be $20 each, and ball joints aren't too expensive either. All easy and cheap to have someone change for you while a wheel alignment is getting done.
    The 1972 HQ Kingswood
  21. #21
    Grennan's Avatar
    Grennan is online now Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    Yeah my mechanic said the tie rod ends will be the only things to suffer. On cars of this age anyway they will be well and truley worn so if they havent been changed them this is a good oppurtunity.
    - Black Manual VX SS Series II -
    Stealth Mode Activated
  22. #22
    GTP 85's Avatar
    Aug 2006
    lol i think we are getting a bit mixed up here.
    in all my posts i was referring to the INNER- rack ends. Sorry if i confused anyone.
    There are the tie rod ends on the outside, and the inner rack ends on the end closer to the steering rack itself, under the rack boots.
  23. #23
    Morton's Avatar
    May 2006
    Oooh, they should be fine. Get yourself a set of Nolathane Z-shape swaybar linkpins to help reduce steering stress, and they should be fine. Ran superlows for quite a while in my VP (and that car suffered 80,000km of hard cornering) and the rack never sprung a leak or became sloppy. I had those nolathane link pins fitted on it though. Tight as a nun's, that thing was.
  24. #24
    Jun 2008
    Quote Originally Posted by Morton View Post
    hahaha.
    Well thats good to hear. I'll take note of those link pins too thanks mate.
  25. #25
    Jun 2008
    Quote Originally Posted by Grennan View Post
    Yeah true. Things would be so much easier if every mechanic said the same thing lol..... thanks m8
  1. Swap: super lows for ultra lows - VN sedan - in Perth
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-08-2008, 12:47 PM
  2. Ultra lows and super lows
    By vnrox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2007, 04:20 PM
  3. looking for pics of superlows and super super lows in a vn
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 10:41 PM
