Results 1 to 12 of 12
Thread: Replacing Handbrake shoes... help please
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Default Replacing Handbrake shoes... help please
    I need to replace my Handbrake shoes. Where can i get them , are they holden only or will repco have them, and how much ?
    Also how do you adjust them ? do you adjust at the wheels or at the handbrake lever ?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Gregorys devotes almost 3 pages for the handbrake shoes so what you ask is more than can be covered easily....but I can scan and email - pm me.
    They rarely fail!
    greenacc's Avatar
    VE Berlina
    Jul 2008
    thanks hako, I have a gregory's ( sticks finger down throat ).. I will figure out the fitting bit, but still not sure where I can get the pads as they are not real common like you said. Can u get them aftermaket ?
    Haydz's Avatar
    Haydz is offline Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    yeah you can get them after market. i have a set. made by protex. i think..
    i got them thru auto pro so must be a common enough part.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    pretty easy to change, if you have any mech background and commonsence its easy as ****
    vr Commodore
    Aug 2006
    Post
    Quote Originally Posted by Zuicider View Post
    What??? I think you are thinking of the rear brake pads which are relatively easy to replace. The rear park brake shoes are located inside the rear disk and are not easy to replace. Sure is you have good mechanical knowledge you can attempt it but the park brake mechanism is full of many small parts so keep this in mind.
    Never be afraid to try new things; remember amateurs build the ark while professionals build the Titanic.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    i got mine from sprint auto parts and from memory they were about $50 (i know harsh)
    Zuicider is right thow they are easy as to change
    just remove the calipers then slide off the drum (with the handbrake off)
    take out the two spring loaded retaining pins then the adjuster then the springs that hold the two together (thats the hardest part same with getting them back on)
    then just re assemble and adjust so they are just free spinning when you get the disk/drum back on the tighter the better but you dont want them to touch at all.
    im not admiring your car im looking in disgust
    Set of thongs
    Dec 2005
    Stonedville
    Quote Originally Posted by cruzn View Post
    as i said its easy as ****, you can also adjust them in the housing so u get more out of them without tighting the cable underneath, works like drum brakes
    greenacc's Avatar
    VE Berlina
    Jul 2008
    thanks guys, this is what i wanted to know. I had one rear disc off about 60 thou k's ago and the shoes were worn out then .... so i'm guessin thed be totally rad-chit by now, no wonder the hand brake dont work too well LOL. Sounds just like changing the drum shoes on the old torana.
    Set of thongs
    Dec 2005
    Stonedville
    have u being doing hand brakies? cos on my 400 k plus vn, they are original and still full of meat
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Nope, i wish i could say yeah , i do hand brakies all the time but no, done maybe 2 of them since i owned it. maybe someone adjusted them wrong in the past and they wore out cos they were touching the drum ? don't know, will be pulling them off to check tho, cos now you got me wondering. The VS even plays a little song when you drive off with te handbrake on .... done that a few times, does that count ?
    Set of thongs
    Dec 2005
    Stonedville
    haha bloody oath
  1. Replacing Handbrake Cover
    By criten in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2008, 08:18 AM
  2. handbrake shoes mod kit
    By superchargedvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-10-2005, 05:44 AM
