Results 1 to 20 of 20
Thread: Hot Feet??
    VZ 3.6 V6 Berlina Auto
    Oct 2008
    Central Coast
    Default Hot Feet??
    Hey just commodores members,
    i own a 1994 VR commodore executive in excellent condition for its age, bar one thing, when i drive around for 10mins or more, my legs get really hot.
    this happens when the air conditiong is on OR off.
    the hot air hits my left shin, so in line with the back of the centre console, and also there are two pipes down there, and when touched they are super hot after 10 minutes of driving.
    the air conditiong works fine when it is on, both adequately heating and cooling, but the hot air can still come out when it is cooling. the hot air doesnt come out on the passenger side too.
    Any help would be GREATLY appreciated!!!
    vs calais eco
    Sep 2006
    Disney land!
    Not really sure what pipes your talking about mate? Are they the heater line pipes? Would be easier to tell you what is the go with a few pics of the pipes! Also welcome to the site mate
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    Sep 2008
    Oct 2008
    Central Coast
    oh ok mate, sorry, i got some photos of the pipes, this is the same area where the hot air comes from too.
    thanks for a quick reply too
    Attached Thumbnails Attached Thumbnails Hot Feet??-img_1730.jpg   Hot Feet??-img_1729.jpg
    RALLIART Magna
    Krabbyball Champion!
    Sep 2008
    Cairns
    When i bought my VR i experienced this as well.... at first i thought, Crap , something must be wrong here cause lots of heat was coming in. Now i have just put it down to hot air flowing into the cabin cause it's not exactly sealed very well .... not compared to my missus Toyota avalon Grande .... the plastic interior where ya feet go in front are sealed tight to the carpet.
    Oct 2008
    Central Coast
    Quote Originally Posted by JC_1973 View Post
    did u end up getting it fixed? any ideas to what it could be??
    thanks for reply.
    RALLIART Magna
    Sep 2008
    Cairns
    Quote Originally Posted by Milky2106 View Post
    thanks for reply.
    Nah.. just got used to it and don't really notice it now.... i think i noticed it more cause was used to driving around in the Grande which is a top range model so the cabin is plush with heaps of interior comfort and what you pay for workmanship. I never drive her car now cause it is sooo slow
    Oct 2008
    Central Coast
    oh ok, yeah see mine actually gets quite bad, im not being a pussy either, ive put up with it for about a year now, it seems to have gotten worse though now??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There is a clip attached to a cable just where the pipe gets hot and it can get dislodged. This prevents the heater tap turning off. Normally when the air selector is set to cold the heater tap will be off and the pipes in the picture will be stone cold. If they get hot this means the heater switch is not operating correctly probably due to the clip being dislodged.
    This pipe should only get hot when the heat/cold selector is in the red section.
    RALLIART Magna
    Sep 2008
    Cairns
    Quote Originally Posted by hako View Post
    I did not know this... gonna check it out on my car tomorrow, i have noticed that the pipes do get really hot when the selector is in the blue... cheers
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Hako is correct. however i've just had a look at hte pic you provided and the clip is secure, however the previous owner (or possibly the person who did the sound intall) had it loose at some stage and didn't put it back correctly. when you turn the heater control to full cold have a look at the white plastic bracket that the metal rod is attached too (when you turn the temp control to hot it should move towards the front of the car) whne turning to full cold the white plastic arm should push against a little black valve with vacuum lines attached. the valve controls the vacuum to the heater tap (and shut of the hot coolant from coming into the cabin)
    as for the problem with air always blowing at your feet, it sounds like one of the vacuum lines has come off the control unit. you would need to remove the front facia from the stereo/air con controls and remove the control unit and see if any of the vac lines have been dislodged or cracked etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    VR
    May 2008
    ... hot flushes are generally symptomatic of menapause. Are you also feeling tired & irritable, with a need to blame your problems on those around you?
    If so - menapause.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Quote Originally Posted by immortality View Post
    whats the answer to this if you have climate rather than aircon?
    air blows only onto feet now, Im sure it worked when I first got the Calais, but not now....
  15. #15
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Had the same problem (hot pipes) used the method above and worked a treat
    I had to put the white clip right a the end of the thread on the rod (closest end to the the back of the car) to release the clip insert a small flat head screwdriver in the joint and turn and it clicks/pops off and then reposition it.
    it does not spin down the thread when you turn it!
  16. #16
    VP Executive R-spec
    Jan 2005
    ^ it's all true, I picked up my VP on a 38c day with fires all over Victoria, I drove it home 3 hours from Geelong with wobbly retreads and the heater stuck on :P, great fun. That little white thing needed taking off and putting back on properly
  17. #17
    VRII Acclaim
    Jul 2005
    Heater pipes getting hot
    Read down to this post: Heater pipes getting hot
    When you turn the temperature fully cold (anti-clockwise) you should hit this vavle which will stop hot water running through these pipes. Instructions are there on how to adjust. If you turn it fully cold and the taps are getting hot you need to do some more adjustment.
  18. #18
    Johnno.o is offline Johnno
    Vs Executive
    Nov 2006
    St.Marys Sydney
    Default heat on feet
    I had the same problem, this is how I fixed it, the white plastic lever that pushes the valve in I put a piece of plastic hose on the end of the lever where it touches the valve, that stopped any heat and also stopped the heater pipes getting hot(simple fix)
  19. #19
    Apr 2006
    Auckland NZ
    Quote Originally Posted by NORTI View Post
    you still have a vacuum problem. check the main vacuum source. the problem with climate air is that everything is controlled from that very expensive (to replace) control panel
  20. #20
    VRII Acclaim
    Jul 2005
    I had problems with my shut-off valve not activating the heater valve. Adjusted the rod so it was really pushing on the switch but it would only sometimes work usually if I pushed it a little harder. Just went a got a new shut-off valve from holden, part no: VS21066 called a "Switch - Vacuum". Cost me $20. Only one screw holding it in, two vacuum hoses on it. Took about 5 minutes to swap, just in an awkward spot. Old one was black, new one is white.
    Had a look at the old one, there is a spring inside with a seat that slides. The switch itself moved freely and the spring worked ok, so I assume it was the seat not sealing properly. Could try lubricating but that might cause leaks or dirt to sit in the lubricant and cause problems later on. New one went in and shes good as new, pipes no longer hot. Just remember though that the coolant wont circulate fully, so switch it off cold every now and again to flush it out.
  1. hissing near feet
    By robby88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 05:50 PM
  2. VP - air only coming out at feet
    By ben k in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2007, 08:24 AM
  3. Hot Feet
    By hardlyevolved in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2007, 07:09 PM
  4. Need small feet
    By dam13n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2005, 08:38 PM
  5. Wet Feet
    By sharpeidog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2005, 06:51 AM
