Results 1 to 9 of 9
Thread: exhaust question
    Oct 2007
    Default exhaust question
    ok so im wondering if you can fit an exhaust from say vt-vy on say a vs with and IRS rear end?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    anything is possible if you want to modify things, a vs statesman supercharged has a duel exhaust, maybe this is a better way to go at might fit a bit neater
    Oct 2007
    im talking about v8 exhausts they look very similar and there are lots of prefebed systems going cheap for gen's thats why i ask
    VP Executive R-spec
    Jan 2005
    They fit with a very few slight alterations (not much) My local exhaust shop allways uses them to make systems for VP-VS IRS
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I put a VX twin onto a VS with IRS, to say that it requires a little modification is an understatement. They do fit, but the front has to be remade, the hangers moved, and the under axle pipes and rear muffler is in a totally different position. A lot of heating and bending, it won't look pretty. Or some pipes will have to be removed and remade.
    Visit my Facebook page
    Oct 2007
    awesome thanks for the replys got some good quotes from local exhaust mobs but the question now is twin 2.5" or 3"?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Spend the money on the correct system for the car. It will look all chopped up and crappy if you use the VT-VX system IMO.
    Jun 2005
    is it for a v6 or a v8? either way, twin 3 inch will be massive overkill, or did you mean single 3 inch
    someone mentioned a stato exhaust. this wont fit either without modifications. theyre about 4 inches too long i believe. i put a statesman exhaust on mine and i had to cut out a big section between the cats and the mufflers
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Oct 2007
    its a v8 and im not sure which one to get twin 2.5" or single 3" from what i ave read some say twin 2.5 is a bit much with out stroking but single 3" is louder etc
  1. Exhaust question
    By bennzy in forum LSx Development and Modification
    Last Post: 05-04-2012, 02:41 PM
  2. Exhaust question
    By tonitrus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2006, 10:14 PM
  3. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  4. vn exhaust question?????
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2005, 07:26 PM
  5. Yet another exhaust question
    By petesvns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2005, 10:23 PM
