Results 1 to 4 of 4
Thread: Noisy A/C compressor VR
    VR Executive
    Jan 2008
    Default Noisy A/C compressor VR
    Travelling home last night with the A/C on and noticed a tinny rattling/grating noise coming from under the bonnet. I pulled over immediately, left the car running and one by one, switched things off to try and troubleshoot the problem. I noticed that the noise immediately stopped when i switch off the A/C. If i started the A/C again the same scary sounding noise started. So, it appears the noise is the A/C compressor. The A/C still blows cold air. Just wondering if anyone else had this problem ? Also, could it just be the clutch on the compressor thats rattling and if so, can you just replace it and leave the compress there. Any help much appreciated. cheers.
    VR Executive
    Jan 2008
    Mar 2008
    Sounds like you have worn compressor or clutch. You can replace clutch only but you still need to take the entire compressor off ie degas + regas etc. You also need specialised clutch removal tools to do it. In this case I suggest second hand compressor since labour cost of replacing the clutch only is more expensive then labour cost for compressor replacement. It is sometimes very hard to pinpoint where the noise is coming from ie you can replace the clutch and still have the same problem. The only time I would be looking at replacing clutch only on Commodore is if the compressor was almost new and it was a definite electrical problem with the clutch itself.
    Mar 2008
    stuffed bearing in the compressor
  1. [TAS] WTB air con compressor for vr
    By psivyv6 in forum Swap / Wanted to Buy / Trade
    Last Post: 09-07-2009, 01:04 PM
  2. Noisy Air Con Compressor
    By sutto in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2009, 01:24 PM
  3. Vs V6 air con compressor help!!!!
    By Frog201 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2008, 11:36 PM
  4. vk compressor
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-01-2006, 08:30 PM
  5. Noisy Air Con
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2005, 01:56 AM
