Results 1 to 6 of 6
Thread: central locking, all exept one
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default central locking, all exept one
    hi again, im havinga problem with one door central locking, i think its trying to be a unique and beautiful snowflake, (sorry watchd fight club last night)
    any way, the other 3 doors lock fine but the left rear door refuses to lock (under central locking) i have to manualy push the bastard down everytime i get outa the car
    any ideas what could be wrong/how to fix it?
    VRII Acclaim
    Jul 2005
    Easy fix is to get some silicon spray/wd-40 etc and spray around the lock so that it will run down the lock. Give it a really good spray. Sit in the car with the remote and keep locking and unlocking the doors. As you lock the door, put a little bit of pressure on the lock to help it. If it does go down with a little bit of help, you know it is at least partially working. Help it out a couple of times and eventually it will start to lock without help. Sometimes you just have to wait until the next day so that the lubricant has time to work its way down.
    This will fix it, maybe for a year, and you will probably have to do this again when it starts playing up.
    Better fix would be to pull the door trim off, lubricate all the moving parts and check for parts that are causing the problem.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In addition to Kopper69's advice, check the power wires to the door where they exit the B pillar and also where they connect to the lock solenoid. Strange how its generally the left rear door that gives trouble.
    VR
    May 2008
    So the back left one unlocks okay but wont lock? Or it's not working at all?
    When I got my car, I found out one of the locks wasn't working at all unless I did it manually. Put up with it for a bit, till I got sick of accidentally leaving the back door unlocked. Popped off the door skin & found out that the previous owner have chopped out half the central-locking loom. I can't for the life of me figure out why someone would do this. In fact I found a ton of things that the knob tried to jerry-rig & cocked-up.
    Some people shouldn't be allowed to reproduce, but I digress ... I ended up replacing the loom. Cost 20$ & took 15 mins.
    - I suggest getting the skin off & having a good look.
    Nov 2008
    rotorua, NZ
    cheers bro, ill have to do that, i tryd the crc down the lock but that made no improvement, looks like ill be pulling the panels off, it unlocks fine but dosent lock btw lol
    thanks again guys, ill let you know how it goes
    Nov 2008
    rotorua, NZ
    problem sorted, i replaced the motor, it was shot to sh!t, and lubed all the moving parts, sorted
    now it locks fine
    brilliant
  1. central locking in vn
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 07:47 PM
  2. Central Locking
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 04:26 AM
  3. central locking
    By stewart in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 02:23 PM
  4. Central Locking
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 02:18 PM
  5. Central Locking
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 07:27 PM
