Results 1 to 9 of 9
Thread: ABS off light is on
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Default ABS off light is on
    Just got my car back from the mechanic and i noticed that the abs light is saying "ABS off" what could this mean???
    VS Calais
    Nov 2008
    Could mean low battery voltage. When the battery/alternator starts to go, ABS is one of the first things to go.
    Trayner's Avatar
    Aug 2008
    hmm pulled the fuse out and put it back in, and it went away. Might just have to keep watching it
    Trayner's Avatar
    Aug 2008
    dang was working for like 5 mins then the "ABS off" light turned back on
    Man this is so annoying
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by trayner View Post
    What was done to the car by the mechanic?
    MY RIDE
    Trayner's Avatar
    Aug 2008
    Quote Originally Posted by accentstencil View Post
    New springs and shocks , and changed the head gasket to get a RWC
    i was looking thru the fuse box and the ABS is sposed to have a 10a fuse , but there was a 15a there insted, so i used a spare 10a and the light didnt come on, Could this be why the light kept coming on??
    JJ's VR's Avatar
    JJ's VR is offline VRHLDN
    VR 3.8lt Supercharged 163.8kW & VS sII HSV Senator
    May 2006
    [QUOTE=trayner;954340]New springs and shocks , and changed the head gasket to get a RWC
    check your wiring connections at the back of each brake rotor where the ABS sensors are, perhaps while fitting new shocks and springs mechanic might've knocked one of your sensors loose??
    And, yes try to stick to the recommended fuse amperages
    VRII Acclaim
    Jul 2005
    In the how-to section I have made up instructions on checking the abs error log. That will tell you why the light is coming up and point you in the right direction.
    ABS Error Codes
    Different fuse wont be why the light was coming on. I would put the recommended fuse in. Maybe the mechanic noticed the light came on, fuse was blown and popped another fuse in there?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's also possible the 15amp fuse was open circuit or otherwise dodgy like a lot of cheap fuses on the market. Open circuit would make the ABS OFF light come on.
LinkBacks (?)
  1. 01-02-2009, 08:53 PM
  1. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
