Results 1 to 16 of 16
Thread: VS HSV Automatic ride height adjuster?? wtf?
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default VS HSV Automatic ride height adjuster?? wtf?
    Hey guys, something just reminded me of something my mechanic told me a while ago. He reckons on my VS Senator, it has something like an automatic ride height adjusting system or some crap like that, and when i jack it up to avoid it automatically adjusting the ride height, i should pull the pin on the compressor that's under the car somewhere.
    Wtf is that? Never heard of it on early model HSV's, i thought it was something on later model Holdens / HSV's etc.
    Anyone shed some light on this, or is my mechanic just getting old and seenile?
    VR V6 Manual
    Aug 2008
    Central Coast, N.S.W
    we had an old fairlane that had standard air bag suspension. and it used to adjust itself to a certain ride height. it was an ed model equivalent fairlane.(i dont know what those were called)
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Toms Senator sig has it, and i know for a fact VR Clubby wagons and VS Manta wagons get it, not sure about sedans tho.
    Its just called self leveling suspension.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Hmmmm, am i right in saying the compressor (if it has one) is located around the back of the diff housing somewhere?
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    it was (afaik) an option on models with IRS. it basically uses pump up air shocks to raise the rear end when it is under load ie. towing, full boot etc.
    commonly found on the statesmans and caprices in the VR/S range, but obviously HSV must have had some installed as well. as to where the compressor is located, i have no idea, but around the rear end would sound about right. ill see if i can dig up some more info on them
    CC
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I've recently installed Level Ride to my WH but I reckon the components will be in the same place on a VS. The compressor is at the rear on the passenger side, sort of up beside the diff. The height sensor is on the driver's side with one part connected to the control arm and the main part of the sensor is bolted to the chassis. I think your mechanic meant for you to disconnect the sensor when jacking up your car. Pull the link thing that goes to the control arm off.
    If you have level ride suspension I'm surprised you haven't heard the compressor cutting in (or mine might be excessively noisy) or noticed the air shocks.
    Attached Thumbnails Attached Thumbnails VS HSV Automatic ride height adjuster?? wtf?-ride-height-sensor.jpg
    MY RIDE
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Awesome thanks guys! Been a huge help!!
    I'll get under it and have a look properley today, so drivers side beside the diff and around that area i should be looking? Can't say i have heard the compressor make any noise, i can hear the fuel pump buzz but that's about it when i turn the ignition on. Can't say i have heard any other noises out of the ordinary.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Cobez View Post
    The compressor is on the passenger's side and the sensor is on the driver's side. Just stick your head under and see if you have air shocks.
    My compressor is pretty loud but I bought it second hand on ebay so I don't really know how much noise they should make.
    MY RIDE
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Well i know i have Pedders shocks front, so if i have them on the rear, i realistically DON'T have the set up for the ride leveller in my car.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    utes have a ride leveler standard i think, i think the best benefit for this is if u have a think of fat chicks
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    LOL. Good call, yeah i don't need it then lol.
    Well i'll post back with what i find later on Cheers guys.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Ok guys, there are Pedders shocks in the rear, and what look to be stock shockers in the front.
    Does the ride leveller only apply to the rear, or the fronts as well? With Pedders shocks in the rear, that means the ride leveller wouldn't affect the rear am i right?
    V-Josh-R.'s Avatar
    V-Josh-R. is offline NEED PACEMAKERS.
    94-VR Commodore Ute
    Jul 2008
    Maybe. What kind of pedders shocks are they but? because when they were installed they could have been set up to still incorporate the levelling system from the stock suspension?.
    Holdens go fast...very fast.
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
    STEALTHY™'s Avatar
    Jan 2005
    Pretty sure its only on the rear.
    cheers sexy
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Yes it is only for the rear. When you are towing or have a lot of weight in the back it just raises the back up to normal height.
    MY RIDE
  16. #16
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Thank **** the stupid system had been taken out. Really couldn't be assed with it.
  1. VX R8 ride height
    By VXHSVR8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2008, 02:27 PM
  2. Height adjuster
    By Spirit in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-03-2007, 03:04 AM
  3. Seat belt height adjuster??
    By aperfectcircle in forum General
    Last Post: 28-02-2007, 08:08 PM
  4. VR Ride Height
    By tr3nt in forum General Discussion
    Last Post: 04-08-2005, 09:03 PM
  5. Ride height
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-07-2005, 11:25 PM
