Results 1 to 7 of 7
Thread: miss under load v6
    vs v6
    Nov 2008
    Cool miss under load v6
    hey there . recently got a vs v6 wagon as work vehicle . anyway previous owner has maintained it religiously always replacing faulty parts and so on . anyway it has just developed a miss under load . sometimes worse than others ,sometimes hardly noticeable . checked the fault codes and comes up with 97 which directs me to the carbon cannister and emission control. cant fault the system after repeatedly going over it .has anyone had a similar problem and rectified it .
    whats the best way of cleaning injectors also . cheers
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I would first check your coilpacks anf DFI for cracks or any signs of corrosion or damage, thats normally the first place to look if it starts missing under load.
    vs v6
    Nov 2008
    Cool thanks
    coil packs have been replaced recently but will check out DFI . thanks mate.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds electrical so go for the simple fixes first - plugs are cheap to replace....then leads. Quickest cheapest way to clean injectors is with injector cleaner in the fuel tank otherwise it becomes costly.
    Reset the codes and test again. Good Luck.
    VRII Acclaim
    Jul 2005
    Would start with the spark plug leads. Cheap and easy, most likely to fix your problem. Couldnt hurt to do the spark plugs while youre there.
    vs v6
    Nov 2008
    Angry changed the basics
    new plugs , leads .fuel filter. new coil pack . still missing under load . today it started to miss as soon as you depressed the accellorator.starts and idles fine but as soon as you apply the gas it splutters . checked the fault codes again comes up 97 .emmission control and carbon cannister .thoroughly checked that too . all seems good
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    code 97 is the canister purge solenoid. i assume you found it , but if not its a little black box at the back of the engine at the top, just near the fuel pressure reg. I had that code once when the connecter came off the solenoid. could be that , or a blocked line going to it , a dead solenoid , or who knows what. If you only got 1 new coil pack did you try it in all 3 positions ?
  1. vp has a miss & pops under load
    By girl racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2007, 12:43 PM
  2. My vr has a miss?? need help??
    By Adz_3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 09:18 PM
  3. Miss firing under load
    By PDS81 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2005, 11:16 PM
  4. miss under load
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2005, 06:44 PM
Tags for this Thread
