i have a vs 5ltr stroker and i just lost all oil pressure to the top of the motor i have changed the oil pump and still nothing can anyone help me
Check the oil pressure relief valve...also make sure the correct oil filter is fitted and fill with oil to help prime the oil pump. Check the oil pickup filter is clean and fitted correctly in the sump.
I had the same thing with my car the day I bought it. It ended up being the oil pickup. It was rooted cause it picked up heaps of **** in the oil. They changed it and worked fine ever since.
time to pull the motor out a see if the pick up is ####ED hope that is all it is i will send you a pic of it lighting it up when it is back on the road thanks
