Results 1 to 5 of 5
Thread: vs 5ltr no oil going to top of motor can anyone help
    VS 5LTR STROKER
    Nov 2008
    Angry vs 5ltr no oil going to top of motor can anyone help
    I lost all oil pressure to the top of my motor i changed the oil pump and still have nothing i packed the oil pump with vaseline and cranked it over and still nothing i have run out of things to do can anyone help me as it is doing my head in big time
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    VT spac super6
    Nov 2008
    Riverton sa
    id say if its not your pump its cam/hydrolic lifters as thats what feeds the top of the heads and rocker gear
    VR CALAIS
    Nov 2008
    I took the pressure sensor out of the pump and filled the pump up with oil through that hole on mine to get pressure after building the engine because it wouldn't get pressure
    VS SII
    Nov 2008
    I used oil based grease on my 308 not hi temp stuff cause that will block evey thing up lol when you rebuild the motor or remove the the pump it needs to be primed so that it can suck oil again some time you can take the sender uint out and try it that way but its safer to use grease
  1. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  2. FULL VT 5ltr CONVERSION EVERYTHING YOU NEED WITH BRAND NEW HSV MOTOR
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 07-11-2007, 12:34 AM
  3. wrecking vn calais 5ltr + vs v6 complete drive train fs *motor, box etc
    By petezor in forum Parts And Other Items For Sale
    Last Post: 28-08-2007, 09:46 PM
  4. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
