Results 1 to 7 of 7
Thread: bigger the whee,l craper drive???
    vs ss commodore pantha mica
    Jan 2008
    bacchus marsh vic
    Question bigger the whee,l craper drive???
    hey just bought a vs ute and has 16 inch mags on it, like my last vs commodre with 17 it pulls when the road is higher than other, really annoys me, they both have no name tyers on em, the ute has new tyres but still does same thing, will good named tyres fix this or is a common problem??
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    im having a bit of trouble understanding what your problem is .........
    Eureka styles!
    LightningVP is offline Donating Member
    None
    Sep 2008
    I have good brand tyres on mine and my car did it for about 500k after i put my 19" on, but doesn't do it so much now unless I'm going really slow
    None
    Sep 2008
    Quote Originally Posted by eurekamad94 View Post
    When he is driving, the wheels follow the ditch in the roads...
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    If they have the same size tyres on em and one rim is an inch bigger (and most likely wider) then your gonna have some tyre roll issues.
    Basically, on the 17, the tyre will be stretched over the 17 more so than the 16, leaving less side wall. The 16 will have some play in the wall under load around corners etc.
    With a bigger rim and less tyre, you get ride issues with bumps and etc because the dampening effect is reduced due to a lack of air etc in the rim. A 15 with rubber is usually the same size as a 17 with rubber as the tyre is designed to be "low profile".
    Pulling may be a likely cause of poor alignment. I believe toe adjusts this.
    Im not sure what your issue is, bit hard to understand... but basically your adding a lot of different ride characteristics to your car when you have bigger rims so you need to ensure your suspension is adjusted to meet the new requirements.
    Jan 2008
    bacchus marsh vic
    Jan 2008
    qld
    probably just needs the toe adjusted any wheel shop can do it for a price
    Eureka styles!
  1. To all Member That Don't Drive A Commodore, What Do You Drive:
    By Evolution_Ends_Here in forum The Pub
    Last Post: 07-12-2008, 05:40 PM
  2. my e-wang is bigger than yours!
    By TWOJZ in forum Car Audio
    Last Post: 01-12-2008, 11:10 AM
  3. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
  4. *i Bigger Better*
    By redcv6 in forum Car Audio
    Last Post: 10-01-2007, 04:46 PM
  5. Want Bigger Rims 20" or Bigger Legally
    By gooley in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 03:15 PM
