My speed alert panel doesnt show my current speed. I've heard its suppose to do this. Is there anyway I can fix this without ripping out my dash?
cheers
the speed alert panel only shows ur over speed that you set it to, so far as i know it doesnt do anything other than that
my mates vs shows his current speed
To show the current speed, you have to press both the up and down button when turning the key on.
You can change the way it operates - from memory I think you hold down the 3 buttons with the engine switched off, turn to accesories and keep holding buttons down - it will beep and 100 appears on the screen then press the set button.
As said above, you have to press the buttons for it to work. Your mate probably does this everytime before he starts his car.
Originally Posted by davway
I think the way Hako explained it will keep it in speedo mode everytime you start the car
I got it to stay on my old VS exec once. Pressed and held random buttons, and 100 did come up like hako said. Had some work done where the battery was disconnected and I could never even get the temporary one to come up again
ex cop cars have this function its like a digital spedo in the speed alert. not sure how they get it to do this tho.
ah tru, yeh my mates one is ex cop car
so is it only ex cop cars then?
No, anyone with a speed alert can do this. Press all three button, turn on your ignition and wait until it beeps and shows "100" on the display. Now press "set" and you're done. It will stay like this until you disconnect it or the battery.
couldnt get mine to do it ***ing shit
When I did what hako says, I get pre-set speeds, P1 = 60, P2 = 80, P3 = 100
up and down buttons pushed together brings the speedo up when you start the car.
you have to press set once 100 appears
you have to press all 3 buttons until 100 appears and the engine light flashes. then press set and it will stay there without the annoying flashing orange light
Bite off more than you can chew, then chew like hell - Peter Brock
If I recall correctly, It takes quiet a while before 100 comes up - Most stop pressing it before it does.
However, It dosn't work on my wifes VR SII, it seems rather random on the cars it works on
Current mods/repairs:
Power Windows Installation (70% Complete)
Current Issue(s)
N/A
My Holden doesn't leak, It's just marking it's territory!
Turn your VS's speed alert module into a permanent digital speedo (not for models with trip computer)
Originally Posted by shaggerz
1) Turn car off completely (key is as far off as it will go)
2) Hold all three speed alert buttons (don't let go)
3) Turn key to on and KEEP holding all three buttons
4) Keep holding for ages
5) Keep holding until 100 appears on the display
6) Let go of all buttons
7) Press set once.
Digital speedo will now be permanent. You can change it back to speed alert by repeating above process.![]()
im a vdo stockist for these, yes you can set them in permanant speedo mode
SIR LS1
the two ton go kart
theres 2 different types guys, the aftermarket one and the factory holden one .... half u guys have the factory and half have the aftermarket one... the aftermarket one does NOT hold speed.
SIR LS1
the two ton go kart
