Results 1 to 13 of 13
Thread: Help...Tap and Die question
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default Help...Tap and Die question
    The thread in the oxygen sensor port on my extractors is stuffed and so is the oxygen sensor thread, my question is has any fix this using a tap and die... urgent...
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    may be easier. to get a new exhaust from the wreckers. i myself have not tried the tap and die method though.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    depending on the costs I guess, three options are present, go to the wreckers, try to tap and die it, cut it off and weld a new lug in there.
    VT
    Apr 2005
    QLD
    You should be able to shop around and get a helicoil to suit that thread. Try your local exhaust shop first. Obvioulsy will involve removal of the header.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Have the headers off already and tried the tap and die method first I used the 18mm x 1.5 tap and die and it seems like the die made it (oxygen sensor thread) to small.
    The helicoil option I`ve heard of this, though will it bring a bit more meat to the pipe?
    failing that I will use a new lug.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    i'd say the oxy sensor would be a bsp thread??? With a helicol you use a oversized tap (specifically for coils) tap it out larger and then screw in the helicoil this brings it back to standard size
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Just to clarify I meant that the threads are the same but it seems to small for the hole and slides in and out so I need more meat in the pipe, I think I`ll go with the new lug option.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default grrrrrr
    Can`t find a 18mmx1.5mm nut anywhere in my town even the agricultral
    circle`s don`t have them grrrrrrrrrrrrrrrr.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    they sell em at Summit Racing but thats in the US so not much use for you. try one of the header manufacturers, they must have em. don't know if they'll sell you one but the'll definitly have em
    Body by Holden, Soul by Brock
    the Legend will live forever
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Yep, I`ve tried case IH and the other agricultral equipment repair places in my town and they don`t use that pacific part I found some via google but
    they sell em in batch`s, $200 for 100. yes $2ea but we don`t sell em single
    grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrr
    Apr 2006
    Auckland NZ
    another option is to go to one of the large machine shops in your area and ask then to tap some 25mm dia steel bar, with 18x1.5mm tap. 5 min operation in a lathe. shouldn't cost the earth. ask on a friday arvo and a box of **** will normally cover the cost for the boys.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by immortality View Post
    All good I found one
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Quote Originally Posted by Haydz View Post
    Ever herd of something called money?
  1. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  2. Sub box question
    By wagonb0y in forum Car Audio
    Last Post: 18-05-2006, 06:43 PM
  3. Question about reg..
    By tyneesa in forum General
    Last Post: 14-11-2005, 06:23 AM
  4. Question!!!!!
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2005, 05:08 PM
