my car seems to be making a bit of a whining noise when my foot is off the accelerator going about 60-70. at most other times and when my foot is on the accelerator it doesnt make the noise but wondering what it could be
anyone have any ideas?
it could be your diff whining.
How long has it done it for?
dont worry, il start a ride thread soon.
my engine whines to f**k, pretty sure mine is just belts overtightened, but if its only doing it at a particular speed i'd be looking more at your box/diff whining not engine.
More explanation is needed![]()
If there's wine in the car take it to an abo they'll find it everytime
commodores
gotta love em
V6 or V8???
if you have a V6 then you cant over tighten the belt...
Where does the noise seem to be coming from? ie from the engine?
I think someone has a gilmo drive they forgot about:
Holdens go fast...very fast.
FORD:
First
On
Rubbish
Dump
:P
S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
its a 6, it sounds like its coming from the engine but pretty unsure
maybe someone installed a supercharger on it overnight...to surprise you for christmass.lol
not sure what you mean by engine whine,but take your belts off the motor start it and rev it and possible a quick run a couple of hundred meters ,it wont hurt it as long as it doesnt get too hot from running too long ,but if it not there, its either the aircon bearings or power steering pump is stuffed .I had a Vp Berlina which I bough from a car yard very cheaply because of an engine whine ,a $30 bearing later every was fixed
whines normally come from stuffed bearings or stuffed gearboxes or diffs, your power steering whines when its low on oil but thats only when your turning normaly and superchargers or gilmour belts or straight cut gears
if its the last 3 then dont worry i wish i had them also
Federation
Against
Rotary
Tossers
