hey guys im having a issue selecting gears
i noticed today i was at the lights stopped when to clutch in the selected 1st gear it was tight as **** then gave it a second go put used more forced and knock it went in it usually happens when the cars warmed up when the cars cold gears go in perfect wat could this problem be
ive changed my gearbox fluid 1 mnth ago also my clutch n clutch cable are only few months old also the gearbox mount rubber was changed 3 months ago
wat else could this problem be caused i noticed 1st gear seems to only be the issue when its real tight going in 2nd not as bad 3rd n 4th and 5th are sweet??![]()
Im having the same problem... reverse is as bad as first at times too ???
--APOC--
yer gets like dat
well im getting my mechanic to check it up 2morow for me he thinks it might be clutch cable outta a slight adjustment
when was the last time u had ur clutch cable checked out?
only bought the ute a month ago so it was at the mechanics then for a look over.
--APOC--
well il let u know how i go its getting checked ova on saturday cheers mate..
hey champ just got home from the workshop my mechanic checked it out and it was outta adjustment the clutch cable give urz a try and see how u go im happy man hehe goodluck cheers let me know how u go cya mate
Another thing it could be.....I changed my gearbox oil a coupla months ago,and my T5 was filled with Auto trans fluid...put the specified manual gearbox oil in it,and it was hard to shift when cold and would graunch going into second,so I drained it,and put auto trans fluid back in it,and it shifts fine again now..
